Re: Who sells Griner trans brake solenoid
[Re: VIPERDUST]
#2266533
03/10/17 12:53 AM
03/10/17 12:53 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would call Hughs or John Cope at CRT to see if they can help you out.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: rebel]
#2266759
03/10/17 01:43 PM
03/10/17 01:43 PM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
what is it with Grinner Brakes? i'm down under & Grinner brakes are rare, i only know 2 racers with them & both have had solenoid issues. Yet whenever someone wants a brake recommendation everyone says Grinner? Im kinda glad i have A&A but was thinking of trying one of John Copes own brand next build. anyone using his on here? I have one of John's brakes but haven't ran it yet. Waiting on a pan from Steff's and the weather.
[Re: VIPERDUST]
#2266803
03/10/17 02:49 PM
03/10/17 02:49 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
See if you can disassemble the solenoid from the assembly to get a number off it to purchase the solenoid only.
The assembly that the solenoid is in is just a modified Governor body out of a 727 trans (clever use of spare parts LOL).
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: VIPERDUST]
#2266911
03/10/17 05:42 PM
03/10/17 05:42 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
tranzact uses the same solenoid...got one brake in use that I bought back in 1993...quality must be pretty good.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: hankcrank]
#2266913
03/10/17 05:44 PM
03/10/17 05:44 PM
Posts: 374 kalamazoo, MI.
VIPERDUST
kalamazoo, MI.
Thanks for the replies. After the trans was refreshed, I had the car running, had all the forward gears, but put it in N and hit the trans button for reverse, and nothing. Got checking, and have power to the solenoid, but solenoid has no response, pulled valve body, removed solenoid, bench tested. Solenoid does not push out, or pull in when I have it extended. Looks like I will be sending the valve body to Tranzact, for Joe is the only one who says he can fix it. Fingers crossed.
