Hemi Ram will not start #2266541
03/10/17 01:14 AM
03/10/17 01:14 AM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I went to store this evening when I came out of store truck will not start. Turns over ok but does not start. How do I check fuel pump.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Hemi Ram will not start [Re: D-50] #2266572
03/10/17 02:30 AM
03/10/17 02:30 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Hey, just so you know, I'm 99% sure that nobody here is a mindreader!
No info on the truck? The year? The model? The engine?
You are probably frustrated and forgot, right?
Re: Hemi Ram will not start [Re: D-50] #2266582
03/10/17 02:50 AM
03/10/17 02:50 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
A quick blip on the fuel rail Schrader valve will let you know if you have fuel pressure...or if you are out of gas!A pressure gauge is best on the same port though.
Re: Hemi Ram will not start [Re: D-50] #2266583
03/10/17 02:54 AM
03/10/17 02:54 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Treed. laugh2
I need to type faster.
As already stated, more info on the vehicle would help.
As far as if the fuel pump is working, there's a test port (schrader valve) on the fuel rails that if you pull the cap off you can depress (push in) the schrader valve (like a tire valve stem) and if there's fuel pressure gas will spray out (or if you have a pressure gauge you could hook it up to the port).
That's the easiest way to see if you're getting fuel on a fuel injected engine.
Beyond that more vehicle info is needed.
Re: Hemi Ram will not start [Re: SNK-EYZ] #2267061
03/10/17 10:02 PM
03/10/17 10:02 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
It is a 2008 Ram 1500 with a 5.7 Hemi. I guess I should check power at the gas tank and see if it is getting power. Where is the fuel pump relay. I have not been able to check anything yet I just got it towed home. Thanks...
Re: Hemi Ram will not start [Re: D-50] #2267878
03/12/17 08:00 AM
03/12/17 08:00 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I had mine conk out in my 275,000 mile 2007 Ram. A tech told me to whack the tank with a mallet. It worked and started and ran ONCE.
I bought a stock replacement pump and he swapped it in in a couple of hours. I figured if the stock pump lasted this long, another OEM pump was a good way to go.
Re: Hemi Ram will not start [Re: D-50] #2267888
03/12/17 08:40 AM
03/12/17 08:40 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The relay should be in the fuse block/TIPM (Totally Integrated Power Module) under the hood next to the battery.
The larger black plastic box with the removable lid.
Here's a video of TIPM problems, the fuel pump relay is one of the problems.
https://www.youtube.com/watch?v=HcV5oAF1hM0
Re: Hemi Ram will not start [Re: SNK-EYZ] #2271471
03/17/17 11:48 PM
03/17/17 11:48 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
X2 whack the tank with a mallet while cranking. I'd say 7 out of 10 times it will start. BTW I just bought a '88 D50 4x4.
