Hemi Ram will not start
#2266541
03/10/17 01:14 AM
03/10/17 01:14 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I went to store this evening when I came out of store truck will not start. Turns over ok but does not start. How do I check fuel pump.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Hemi Ram will not start
[Re: D-50]
#2266572
03/10/17 02:30 AM
03/10/17 02:30 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I went to store this evening when I came out of store truck will not start. Turns over ok but does not start. How do I check fuel pump. Hey, just so you know, I'm 99% sure that nobody here is a mindreader! No info on the truck? The year? The model? The engine? You are probably frustrated and forgot, right?
[Re: D-50]
#2266583
03/10/17 02:54 AM
03/10/17 02:54 AM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
Treed. I need to type faster. As already stated, more info on the vehicle would help. As far as if the fuel pump is working, there's a test port (schrader valve) on the fuel rails that if you pull the cap off you can depress (push in) the schrader valve (like a tire valve stem) and if there's fuel pressure gas will spray out (or if you have a pressure gauge you could hook it up to the port). That's the easiest way to see if you're getting fuel on a fuel injected engine. Beyond that more vehicle info is needed.
[Re: SNK-EYZ]
#2267061
03/10/17 10:02 PM
03/10/17 10:02 PM
D-50
North, Alabama
It is a 2008 Ram 1500 with a 5.7 Hemi. I guess I should check power at the gas tank and see if it is getting power. Where is the fuel pump relay. I have not been able to check anything yet I just got it towed home. Thanks...
[Re: D-50]
#2267888
03/12/17 08:40 AM
03/12/17 08:40 AM
SNK-EYZ
A Red State
It is a 2008 Ram 1500 with a 5.7 Hemi. I guess I should check power at the gas tank and see if it is getting power. Where is the fuel pump relay. I have not been able to check anything yet I just got it towed home. Thanks... The relay should be in the fuse block/TIPM (Totally Integrated Power Module) under the hood next to the battery. The larger black plastic box with the removable lid. Here's a video of TIPM problems, the fuel pump relay is one of the problems. https://www.youtube.com/watch?v=HcV5oAF1hM0
[Re: SNK-EYZ]
#2271471
03/17/17 11:48 PM
03/17/17 11:48 PM
Posts: 858 Southeast Pa.
SALEM1912
Southeast Pa.
X2 whack the tank with a mallet while cranking. I'd say 7 out of 10 times it will start. BTW I just bought a '88 D50 4x4.
