Aluminum manual steering box as core? #2266387
03/09/17 08:37 PM
03/09/17 08:37 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
My old manual steering box is an aluminum piece, #2537349-6. Thinking of using it to cover the core charge on the new piece. Anything special about this one? It's nice and light, just don't want to blow it on a core charge if it's worth more for some reason.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Aluminum manual steering box as core? [Re: busboy] #2266409
03/09/17 09:13 PM
03/09/17 09:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
All manuals are aluminum, what do you think makes yours so special?
At 50 cents a pound for scrap where is it worth more - as scrap or as a core?
Re: Aluminum manual steering box as core? [Re: busboy] #2266456
03/09/17 10:33 PM
03/09/17 10:33 PM
Thinking of using it to cover the core charge on the new pece.
did you try adjusting it? are you going with another 24:1 or a fast ratio 16:1? I'd think a new 24:1 would be pricey & for that ratio just me I'd source a common good used one.
Re: Aluminum manual steering box as core? [Re: busboy] #2266494
03/09/17 11:33 PM
03/09/17 11:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Steer and Gear wants $515 less $195 for a core. Seems to me anyone with a little mechanical ability and the ability to read the FSM could rebuild one. The only bearings you can't find are the caged ball bearings - likely not worn anyway. The bottom roller is an off the shelf item along with the seals at any bearing shop. The top gaskets are non existent but sealant works and is what Steer and Gear use.
There are many opinions on what lube to fill it with and packing it with grease is no easy task. Heating a bucket of stinking goop up on the bar-b-que also leaves much to be desired. I found "corn head grease" to be awesome stuff - but you can only buy it from a John Deere dealership. Put the stuff in a plastic bag and inject it like you're icing a cake. Its thin enough to flow into every void and fill right to the top.
Re: Aluminum manual steering box as core? [Re: busboy] #2266497
03/09/17 11:40 PM
03/09/17 11:40 PM
Middle of Illinois
Ski 61701 Offline
Ski 61701  Offline
Middle of Illinois
I bought 90w lube from Bass Pro shop, its lower end lube for outboard motors.
Re: Aluminum manual steering box as core? [Re: busboy] #2266520
03/10/17 12:28 AM
03/10/17 12:28 AM
busboy Offline OP
busboy  Offline OP
Thanks for the replys, I'm no expert so your info is much appreciated. Didn't know all manuals were aluminum! Nothing special about mine then, it'll help me keep the cost down on a new one.
Re: Aluminum manual steering box as core? [Re: busboy] #2266576
03/10/17 02:39 AM
03/10/17 02:39 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Wow, I'll sell mine for $195 to whoever wants it.
Sheldon
Sheldon
Re: Aluminum manual steering box as core? [Re: RUNCHARGER] #2266734
03/10/17 01:07 PM
03/10/17 01:07 PM
Canadian shipping is gonna be a killer! I'll get you a good/tight/smooth one to your door for $179.
Re: Aluminum manual steering box as core? [Re: busboy] #2266933
03/10/17 06:26 PM
03/10/17 06:26 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Just rebuild it yourself. You can do it. Firm feel used to sell the kits with the bearings and seals.
I want my fair share
Re: Aluminum manual steering box as core? [Re: busboy] #2267264
03/11/17 10:05 AM
03/11/17 10:05 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have a firm feel rebuild kit I never used PM me if ya want it for less than FF sells it. Very easy to rebuild theses boxes....Only the v8 boxes have bearings the slant 6 ones have bushings....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Aluminum manual steering box as core? [Re: busboy] #2267391
03/11/17 01:59 PM
03/11/17 01:59 PM
Maryland
MoparMike1974 Offline
Maryland
Im betting some Bentonite grease would work well in these.
