Hemi efi dual quad, Edelbrock vs Stage V #2266186
03/09/17 02:03 PM
03/09/17 02:03 PM
Netherlands
72Challenger Offline OP
Netherlands
Anyboday maybe have some experience and or ideas on which intake would perform better, edelbrock dual quad or stage V dual quad, both with port efi?
Would be for a streetcar with 528 KB Hemi, .610" roller cam, Stage V cnc heads with roller rocker setup, 10.5 cr. etc. backed up by 6-speed T56. Most used rpm range would be around 2-3k.
ANy input or experiences here?
Thanks guys.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266191
03/09/17 02:09 PM
03/09/17 02:09 PM
AndyF Online content
AndyF  Online Content
Port EFI? Then why use a dual plane intake? I'd think you would want single plane all the way. It seems like a pain to put bungs into a dual plane intake.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: AndyF] #2266215
03/09/17 03:05 PM
03/09/17 03:05 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The Edelbrock is a single plane intake, I'm pretty sure the the Stage IV one is too.
The Edelbrock has flat pad cast in over the intake ports to install injectors.
I believe that you can even order it new already machined for the injectors.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: AndyF] #2266235
03/09/17 03:41 PM
03/09/17 03:41 PM
central il.
second 70 Offline
second 70  Offline
central il.
Stage V is a single plane and has an efi manifold that is ready for port injectors.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266251
03/09/17 04:06 PM
03/09/17 04:06 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I have used both manifolds on several EFI HEMIs. They both work well. It's a minor point, but the Edelbrock has an air gap which allows hiding some EFI sensor lines and even the regulator return line if you mount the regulator up front between the rails. Also the Edelbrock TB spacing is better suited for normal dual quad air cleaners and you can buy the matching fuel rail kit from Edelbrock which saves you the grief of making your own for the Stage-V.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: SNK-EYZ] #2266282
03/09/17 05:02 PM
03/09/17 05:02 PM
Cool deal, I didn't realize that Edelbrock had introduced an EFI version of that intake. Looks like that is the way to go. Last time I looked at Hemi stuff the Stage V intake was the only single plane one around.
Rich brings up a good point on air cleaner spacing and stuff like that. I've gotten into that mess before using the Stage V intake and then trying to find an air cleaner that fits and works with a fresh air hood.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266291
03/09/17 05:18 PM
03/09/17 05:18 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Tim Banning at FHO may offer a Stage V intake specific air cleaner setup to work with OEM hoods. There's info on his website about this.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: AndyF] #2266295
03/09/17 05:26 PM
03/09/17 05:26 PM
CJD AUTOMOTIVE Offline
Finished up this one awhile back using the Eddy. The stock air cleaner base fit's the TB spacing perfectly. The Eddy rails are made for the manifold and fit correctly.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266319
03/09/17 06:07 PM
03/09/17 06:07 PM
Looks really nice. What ECU did you use with those Holley throttle bodies? Is the linkage 1:1 for the throttle bodies?
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: AndyF] #2266324
03/09/17 06:12 PM
03/09/17 06:12 PM
Customer wanted a Dominator for dual O2's...kinda overkill. Yep, went with 1:1 to start. Tip in is a little sudden, but not as bad as I thought it would be. A progressive might be in the works once he starts driving it a little more.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266325
03/09/17 06:16 PM
03/09/17 06:16 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Where did you get linkage for them? I have a tunnel ram I am going to be using two of those TBs on soon.
68 Barracuda Formula S 340
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266376
03/09/17 08:15 PM
03/09/17 08:15 PM
Ohio
lockjaw-express Offline
Ohio
Monte Smith (RIP) told me to go with the Edelbrock Dual Quad Manifold for my Hemi, and he told me the Holley 112-602 Throttle Bodies would be perfect...He also supplied me with a list of parts so I could go with either the Holley HP or Dominator ECU.
He told me I could run progressive linkage, but he did not think that was necessary for a 3500 lb car with a 4 speed.
For my 440 in my GTX, he told me to buy the Indy Mod Man MPFI intake, and again, use dual 112-602 Race throttle bodies.
Mark
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266404
03/09/17 09:08 PM
03/09/17 09:08 PM
So there must be a setting in the Holley ECU for dual throttle body setups? I haven't looked that far into the instructions yet. I wonder if the ECU cares if the linkage is 1:1 or progressive or maybe it just figures it out by looking at the TPS.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: AndyF] #2266412
03/09/17 09:20 PM
03/09/17 09:20 PM
Yes, if your using two Terminator throttle bodies (injectors in the TB), but if multi port, doesn't matter. You just pick which TPS and IAC you want to use and just leave the other pair unplugged. Linkage doesn't matter, as your just opening the "air leak" faster or slower. Your target A/F will be met either way.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: moparmitch] #2266414
03/09/17 09:20 PM
03/09/17 09:20 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Yes he has
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: CJD AUTOMOTIVE] #2266416
03/09/17 09:22 PM
03/09/17 09:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Can you post a picture with the air cleaner assy installed? Thanks.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 71birdJ68] #2266434
03/09/17 09:52 PM
03/09/17 09:52 PM
Here ya go!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: CJD AUTOMOTIVE] #2266526
03/10/17 12:40 AM
03/10/17 12:40 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
That's my cup of tea, looks stock, but modern. Thanks.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266636
03/10/17 07:04 AM
03/10/17 07:04 AM
Netherlands
Netherlands
The 'air gap' part of the edelbrock was something pointing me into their direction. Might be cooler inlet air and the reason to hide some more wiring / lines etc. but was just wondering if anybody had more input performance wise in the lower rpm range.
Thanks for the input!
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266736
03/10/17 01:07 PM
03/10/17 01:07 PM
Ohio
Ohio
The reason Monte had me go to the Edelbrock for the hemi was because I could machine off the valley cover, and keep my Indy 2 piece valley cover...it worked great, and has plenty of room for the EFI wiring.
Mark
