Steering wheel noise ?? #2266170
03/09/17 01:37 PM
03/09/17 01:37 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
Hey guys !! When I turn my steering wheel it makes a clicking noise and when I hit a bump it shakes/vibrates !! Has anyone had this experience or knows what it is ??
Thanks !
Re: Steering wheel noise ?? [Re: fast414] #2266561
03/10/17 02:13 AM
03/10/17 02:13 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is this a tilt column, and what year vehicle are we talking about? Pretend we don't know what kind of car you have, help us out. Gene
Re: Steering wheel noise ?? [Re: fast414] #2266883
03/10/17 04:34 PM
03/10/17 04:34 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
No tilt and 67 coronet
Re: Steering wheel noise ?? [Re: fast414] #2266912
03/10/17 05:43 PM
03/10/17 05:43 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
The shaking and vibrating on hitting a bump might be caused by loose or worn ball joints. The clicking noise is a bit odd but it would seem to indicate an internal problem with your steering gear.
Re: Steering wheel noise ?? [Re: fast414] #2266956
03/10/17 07:11 PM
03/10/17 07:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Does the column move up and down if you grab the wheel and lift it towards the dash? Does the wheel move up and down or side to side on the column?
I'm thinking the column mounting bolts might be a little loose, or maybe the bushing at the bottom of the column is bad, or has fallen out. Gene
