Re: Where to buy radio suppressor/condensor?
[Re: whomper1]
#2266226
03/09/17 03:23 PM
03/09/17 03:23 PM
Posts: 165 usa
whomper1
usa
yes the one that bolts to the coil bracket, the one in your link is inside of the distributor for the points i need one that looks like the one pictured thanks
[Re: whomper1]
#2266321
03/09/17 06:08 PM
03/09/17 06:08 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I had no luck finding a cheap one.
68 Charger R/T 440 auto
[Re: whomper1]
#2267162
03/11/17 01:20 AM
03/11/17 01:20 AM
Posts: 21,546 N.E. OHIO, USA
A12
N.E. OHIO, USA
I dont want a $40 one i found, so i was hoping there is a cheaper alternative
it doesnt need to have dates or markings
i just want to have it in place on my car
any ideas on where to get?
or a part number that maybe an auto parts store could order one for me?
thanks Are you having radio/audio interference or ignition issues or just wanting to look somewhat original?
[Re: A12]
#2267168
03/11/17 01:24 AM
03/11/17 01:24 AM
A12
N.E. OHIO, USA
Will one of these work: condenser Only $10 + $4.00 shipping MikeR
[Re: A12]
#2269186
03/14/17 09:18 AM
03/14/17 09:18 AM
Posts: 21,500 It's a dry heat
gtx6970
It's a dry heat
Will one of these work: condenser Only $10 + $4.00 shipping MikeR Mike, those are the condenser, mounts inside the ignition distributor. The Noise suppressor mounts next to the ignition coil . 2 very different parts / functions
[Re: whomper1]
#2273917
03/21/17 09:14 PM
03/21/17 09:14 PM
Posts: 566 WA
tman
WA
Standard motor products make several versions. Closest I found is this, if you don't care about appearances or there is one where you change the coil side terminal, but its even expensive. Ebay has some for $30+
http://www.rockauto.com/en/parts/standard+motor+products,RC23,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,RC26,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,RC15,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,JC59,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,RC28,radio+capacitor,21698
