Found my 6000+ rpm vibration.............. #2264538
03/06/17 09:39 PM
03/06/17 09:39 PM
State of confusion
Thumperdart Offline OP
State of confusion
Took my 15+ year old drive shaft in to get new u-joints and a balance and Bruce said it was warped and of course outta balance plus need weight in ft that wasn't there before..........off to the track soon........... drive
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2264553
03/06/17 09:55 PM
03/06/17 09:55 PM
Success! There's a couple of guys on Q&A (right now) who are having difficult balance/vibration/noise issues.
Re: Found my 6000+ rpm vibration.............. [Re: RapidRobert] #2264555
03/06/17 09:57 PM
03/06/17 09:57 PM
State of confusion
State of confusion
Been chasing a miss for a while and thought it was different things but will be 100% sure after I install it tomorrow to test a carb..........
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2264633
03/07/17 12:11 AM
03/07/17 12:11 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I've been told there are 2 balancers for the driveshaft,low & high speed.Marty at SUPERSHAFTS http://www.supershafts.com/ has the highspeed and claims it is better than the lowspeed one if you race,especially at high RPM.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Found my 6000+ rpm vibration.............. [Re: hemi-itis] #2264670
03/07/17 01:09 AM
03/07/17 01:09 AM
State of confusion
State of confusion
I asked him about that and he aid he has the "Cadillac" of balancers and that he spins em to around 3200 iirc but will ask again tomorrow when I pick it up...........
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265027
03/07/17 06:01 PM
03/07/17 06:01 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
That warped thing is a little disturbing. Is it a stock type shaft? If it is, you are starting to push the limits of it as it is trying to "jump rope." Time to step it up to C/M!
Re: Found my 6000+ rpm vibration.............. [Re: Dave Hall] #2265031
03/07/17 06:12 PM
03/07/17 06:12 PM
State of confusion
State of confusion
My bad, out of round by .008-.010 and enuff to shake the dial indicator pretty badly and also needed ft. weight w/a couple welded on washers. I will install it after business stuff then test maybe later or tomorrow.............. luck It is CM w/1350 spicers
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265059
03/07/17 06:51 PM
03/07/17 06:51 PM
AndyF Offline
AndyF  Offline
The driveshaft is a good thing to check on once in a while. Especially on a car that gets beat on hard. Not a bad idea to pull the driveshaft out every couple of years or so and have it spun.
Re: Found my 6000+ rpm vibration.............. [Re: AndyF] #2265085
03/07/17 07:40 PM
03/07/17 07:40 PM
State of confusion
State of confusion
No kidding and 15 years later it was like riding a hard tail above 6 grand.................lol
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265122
03/07/17 09:01 PM
03/07/17 09:01 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Tested it, yet?
Re: Found my 6000+ rpm vibration.............. [Re: BradH] #2265134
03/07/17 09:21 PM
03/07/17 09:21 PM
State of confusion
State of confusion
Nope, no time till tomorrow morning at this point but can't wait.............Bruce mentioned POSSIBLY needing an output shaft bushing but I will drive it first............ luck
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265140
03/07/17 09:28 PM
03/07/17 09:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
At 15 years, yes you Most likely do need one. Change it while the shaft is out. As I recall it wasn't that hard or expensive. 15 bucs maybe ,if that.
Well unless the shaft is in already. If it is you can still grab front driveshaft yoke and move it back and forth to see how much play you have.
Re: Found my 6000+ rpm vibration.............. [Re: Sport440] #2265157
03/07/17 09:46 PM
03/07/17 09:46 PM
State of confusion
State of confusion
The trans is on 7 years..............It felt pretty good and will know for sure tomorrow............. thumbs
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265676
03/08/17 05:36 PM
03/08/17 05:36 PM
State of confusion
State of confusion
Feel stupid posting this w/Monte's passing but the vibration is gone and smooth as glass so next thu. at Irwindale for an all out 1/8 th pass.........went 6.15 @109 slightly lifting w/a 1.33 60 ft. Any guesses...........RIP Mr Monte Smith.......... angel
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265704
03/08/17 06:30 PM
03/08/17 06:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
Good luck, save the best for last up devil
Dig out your old slips and look at the 330 scope , I don't think any track will kick you out based on those times devil whistling wrench
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265705
03/08/17 06:32 PM
03/08/17 06:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What were the changes again,weight loss and elimination of vibration??? work
Re: Found my 6000+ rpm vibration.............. [Re: Sport440] #2265719
03/08/17 06:40 PM
03/08/17 06:40 PM
State of confusion
State of confusion
Since last time out I found a bad coil wire so installed new wires then this vibration has been plaguing me for years but just got REAL bad. Aero tricks to relieve pressure in the rear and an air damn in ft plus removed the turbulent 6-pack scoop and finished my sealed/damned air pan.......... And 17 lbs removed fwiw............. beer Check out my FB pages.....Dominic Thumper or ThumperCarbs then you can see all of these changes........... thumbs
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265788
03/08/17 08:46 PM
03/08/17 08:46 PM
Mo.
racerx Offline
racerx  Offline
Mo.
what scoop did you replace it with?
Re: Found my 6000+ rpm vibration.............. [Re: racerx] #2265826
03/08/17 09:50 PM
03/08/17 09:50 PM
State of confusion
State of confusion
None.........doing the yarn testing soon to verify a few things..........you'd have to go to FB to see what I mean since my I phone pics go straight to FB............ thumbs
Re: Found my 6000+ rpm vibration.............. [Re: Thumperdart] #2265855
03/08/17 10:37 PM
03/08/17 10:37 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Was the 6 pac hood sealed and with a airfilter? They worked fairly decent when sealed. Saw your new style on fb, haven't seen any results with those. Don't know how it will compare. I like that your testing it though. Could be better or worse??. shruggy
Weight loss is good, as is the front lower spoiler. Your car is running better then it was before when it wasn't breaking up. So it was still picking up so I don't think you totally lost a cylinder. If it just was breaking up across the stripe, that wont have to much effect.
So, I cant put any number on it as of yet. Hope it picks up though. up
