Re: Found my 6000+ rpm vibration..............
[Re: Thumperdart]
#2264553
03/06/17 09:55 PM
03/06/17 09:55 PM
RapidRobert
Success! There's a couple of guys on Q&A (right now) who are having difficult balance/vibration/noise issues.
[Re: RapidRobert]
#2264555
03/06/17 09:57 PM
03/06/17 09:57 PM
Thumperdart
State of confusion
Been chasing a miss for a while and thought it was different things but will be 100% sure after I install it tomorrow to test a carb..........
[Re: Thumperdart]
#2264633
03/07/17 12:11 AM
03/07/17 12:11 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I've been told there are 2 balancers for the driveshaft,low & high speed.Marty at SUPERSHAFTS http://www.supershafts.com/ has the highspeed and claims it is better than the lowspeed one if you race,especially at high RPM.
[Re: hemi-itis]
#2264670
03/07/17 01:09 AM
03/07/17 01:09 AM
Thumperdart
State of confusion
I asked him about that and he aid he has the "Cadillac" of balancers and that he spins em to around 3200 iirc but will ask again tomorrow when I pick it up...........
[Re: Dave Hall]
#2265031
03/07/17 06:12 PM
03/07/17 06:12 PM
Thumperdart
State of confusion
That warped thing is a little disturbing. Is it a stock type shaft? If it is, you are starting to push the limits of it as it is trying to "jump rope." Time to step it up to C/M! My bad, out of round by .008-.010 and enuff to shake the dial indicator pretty badly and also needed ft. weight w/a couple welded on washers. I will install it after business stuff then test maybe later or tomorrow.............. It is CM w/1350 spicers
[Re: AndyF]
#2265085
03/07/17 07:40 PM
03/07/17 07:40 PM
Thumperdart
State of confusion
No kidding and 15 years later it was like riding a hard tail above 6 grand.................lol
[Re: Thumperdart]
#2265140
03/07/17 09:28 PM
03/07/17 09:28 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
At 15 years, yes you Most likely do need one. Change it while the shaft is out. As I recall it wasn't that hard or expensive. 15 bucs maybe ,if that.
Well unless the shaft is in already. If it is you can still grab front driveshaft yoke and move it back and forth to see how much play you have.
[Re: Sport440]
#2265157
03/07/17 09:46 PM
03/07/17 09:46 PM
Thumperdart
State of confusion
The trans is on 7 years..............It felt pretty good and will know for sure tomorrow.............
