1972 340 Demon V21 hood performance treatment. #2264506
03/06/17 08:42 PM
03/06/17 08:42 PM
Bradford, Ontario
Barrelhouse Offline OP
Bradford, Ontario
What is the OE correct shade of Black used on my V21 , J54 sport hood equipped Demon. Ive seen them painted flat Black, Semi gloss Black and i need to know what shade was applied from the factory i want it to be just as it was from the assembly line, thanks Moparts great site with great members.
Re: 1972 340 Demon V21 hood performance treatment. [Re: Barrelhouse] #2264515
03/06/17 08:58 PM
03/06/17 08:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Organosol Black
Re: 1972 340 Demon V21 hood performance treatment. [Re: Barrelhouse] #2264522
03/06/17 09:09 PM
03/06/17 09:09 PM
Bradford, Ontario
Bradford, Ontario
Hi Scott does this paint have a smooth finish or is a textured one ?, is it hard to get these days.
Re: 1972 340 Demon V21 hood performance treatment. [Re: Barrelhouse] #2264686
03/07/17 01:37 AM
03/07/17 01:37 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
It has a light texture/orange peel to it.
The original paint was old school lacquer (PPG DDL9355), so if you want 100% oem perfect that is what you need to track down. There are other modern versions of the paint from various sources that can be made to look close enough. Many of the new versions of this paint lack the aluminum and/or they don't texture out properly. You can add silver micro flake and texture additive back in + play with the spray technique and get it to lay down much closer to original product.
Download the images from Moparcanuck to see what it's supposed to look like.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/7871271/site_id/1
More info on alternatives...
https://board.moparts.org/ubbthreads/ubbt...tml#Post2256886
Re: 1972 340 Demon V21 hood performance treatment. [Re: Barrelhouse] #2264708
03/07/17 02:35 AM
03/07/17 02:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Go watch this video Organosol Painting by Cody
Re: 1972 340 Demon V21 hood performance treatment. [Re: ScottSmith_Harms] #2265534
03/08/17 12:58 PM
03/08/17 12:58 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Scott ,thanks for that link. Never visited that website !!
