1978 Dodge Magnum 2 speed wiper motor crank arm eccentric #2264658
03/07/17 12:44 AM
03/07/17 12:44 AM
out west
7T1_DEMON Offline OP
out west
Hey guys I'm posting for an older friend of mine without a computer. He has a 1978 Dodge Magnum 9k original miles with two speed wipers that quit working. Upon inspection of the wiper motor we found some plastic pieces literally that turned to dust..We found a new re-engineered ? 75-79 B body wiper repair kit on ebay that best we could tell were what his used to look like before it turned to crumbles..The kit came with no instructions but after looking at the pieces and the crank arm it looks like maybe this repop kit is for 3 speed wipers. Is there anyone familiar with this issue and is there anyone that makes the plastic cam and other pieces for the 2 speed wipers? Sorry for being long winded and thanks for any help!!
Steve
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2264793
03/07/17 12:04 PM
03/07/17 12:04 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not that this answers your question but I read a while back (unless that has changed since) that the repro pieces didn`t hold up very well.
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2265641
03/08/17 04:05 PM
03/08/17 04:05 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
With "1978 Magnum" in the title, I'm sure Bill, the MagnumGuy, will be by with some input.
I know the plastic bits fail. But I don't know the interchange between 2 and 3 speeds.
I'll send Bill a text and see if he can tell you more.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2265941
03/09/17 12:44 AM
03/09/17 12:44 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I don't believe there's any difference in the 2 sp or 3 speed w/intermittent wipe.
If you bought the recent eBay piece I believe those will work. I will dig around, I have a non-plastic bushing repair "how to". I will post it when I find it.
Tell your friend to get a computer and join my Magnum page on Facebook.
https://www.facebook.com/groups/146952895354657/
http://www.forcbodiesonly.com/mopar-foru...32/#post-341074
"Multiple Magnum owner since 1978!!"
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2267097
03/10/17 11:14 PM
03/10/17 11:14 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Bump.
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: Magnumguy] #2273289
03/20/17 09:55 PM
03/20/17 09:55 PM
out west
out west
thanks for the reply! i will,try to post some pics of his arm as we looked and tried to figure out the ebay replacement pieces..
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2301638
05/09/17 11:09 AM
05/09/17 11:09 AM
Virginia
JimG Offline
JimG  Offline
Virginia
I'm rejuvenating this thread for a friend who has a '78 Monaco. His car had the same problem as the OP's Magnum, and he was wondering about the eBay kit that I've linked below.
http://www.ebay.com/itm/Mopar-75-76-77-7...W-/401103373624
The description is vague... does anyone know how difficult it is to install, if any special tools are required, or if it is a decent solution? Of course, if there is a better solution out there, he'd like to know about that as well.
Thanks!
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2305997
05/17/17 12:17 PM
05/17/17 12:17 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Relatively easy. Once your done, you'll say, overall, not so bad. 1st time doing anything is a PIA.
Re: 1978 Dodge Magnum 2 speed wiper motor crank arm eccentric [Re: 7T1_DEMON] #2306089
05/17/17 02:24 PM
05/17/17 02:24 PM
P
Porter67 Offline
Porter67  Offline
P
Post the pics of what you need, ive several two speed arms I will never use after converting my stuff to three speeds, ect.
Ive seen the ebay prices in the silly 20-40 dollar range, I just cant see it.
