Carter AFB/ Edelbrock Tops #2263872
03/05/17 07:03 PM
03/05/17 07:03 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
In order to use the original 4-barrel air cleaner with the 4 7/32" opening, I'm thinking of replacing my Edelbrock top cover (with the 5 1/8" inlet) with one from an earlier AFB with the 4 7/32" inlet. Design is similar and it looks like it would work but am I missing something? Anybody done it?
Adapter rings aren't practical here.
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2263887
03/05/17 07:40 PM
03/05/17 07:40 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you use an Edelbrock 1405/06 it's no problem at all.
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2263889
03/05/17 07:42 PM
03/05/17 07:42 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Have you had any luck finding air filter to carb gaskets? ( besides making one?).... I suck at making them.....
Re: Carter AFB/ Edelbrock Tops [Re: minivan] #2263904
03/05/17 08:12 PM
03/05/17 08:12 PM
The circular gasket? I just cut/snip/add as required for the circle I need & join the ends & glue em with a touch of super glue on the bottom of where the ends meet so above that point is still pliable & can be lightly crushed for a good seal.
Re: Carter AFB/ Edelbrock Tops [Re: minivan] #2263914
03/05/17 08:25 PM
03/05/17 08:25 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
http://www.jegs.com/i/Fel-Pro/375/2102/10002/-1
Looks like it's Felpro p/n 2102.
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2263917
03/05/17 08:29 PM
03/05/17 08:29 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't know the answer to your question. But is there a later model air cleaner base that will fit your air cleaner top with the larger opening? I have both 67 and 68 air cleaner bases and have had luck solving this problem by switching bases.
Re: Carter AFB/ Edelbrock Tops [Re: ScottSmith_Harms] #2263934
03/05/17 09:02 PM
03/05/17 09:02 PM
Rio Linda, CA
Rio Linda, CA
It is a 1406. What's unique about them compared to others?
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2263939
03/05/17 09:11 PM
03/05/17 09:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nothing really unique but they are the closest to the Carter AFB and CFM as compared to the 60's era Carters.
These Hemi clones are based on 1406's
Re: Carter AFB/ Edelbrock Tops [Re: Jeremiah] #2263968
03/05/17 09:59 PM
03/05/17 09:59 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Thank you...
Re: Carter AFB/ Edelbrock Tops [Re: BSB67] #2263969
03/05/17 10:01 PM
03/05/17 10:01 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Yes their are.. I found one at a wrecking yard in case I want to use a newer carb on my car with my stock Air cleaner...
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2264210
03/06/17 11:13 AM
03/06/17 11:13 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I'm running a 1406 on the rear and a 1407 on the front with progressive linkage. My lids are off 273 hi-po afb's.
Re: Carter AFB/ Edelbrock Tops [Re: Jeremiah] #2264213
03/06/17 11:22 AM
03/06/17 11:22 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can get the "correct" gasket here.
http://quadrajetparts.com/misc-gaskets-seals-c-299_130_134_135.html
Re: Carter AFB/ Edelbrock Tops [Re: 62maxwgn] #2264806
03/07/17 12:27 PM
03/07/17 12:27 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
That's an interesting website.. TY
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2266313
03/09/17 05:56 PM
03/09/17 05:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have 750 carters with the old AFB tops on them.
Re: Carter AFB/ Edelbrock Tops [Re: JohnRR] #2266442
03/09/17 10:11 PM
03/09/17 10:11 PM
John you didn't happen to save the 750 tops did you?
Re: Carter AFB/ Edelbrock Tops [Re: RapidRobert] #2268669
03/13/17 03:43 PM
03/13/17 03:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No I bought them that way , sorry.
Re: Carter AFB/ Edelbrock Tops [Re: JohnRR] #2268710
03/13/17 04:48 PM
03/13/17 04:48 PM
alright, thanks brother.
Re: Carter AFB/ Edelbrock Tops [Re: John_Kunkel] #2268752
03/13/17 06:09 PM
03/13/17 06:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, they fit 600's, 750's and 800's. I build clones of all 3 sizes but for nearly anything streetable the 600's are plenty.
