Carter AFB/ Edelbrock Tops
#2263872
03/05/17 07:03 PM
03/05/17 07:03 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In order to use the original 4-barrel air cleaner with the 4 7/32" opening, I'm thinking of replacing my Edelbrock top cover (with the 5 1/8" inlet) with one from an earlier AFB with the 4 7/32" inlet. Design is similar and it looks like it would work but am I missing something? Anybody done it?
Adapter rings aren't practical here.
Re: Carter AFB/ Edelbrock Tops
[Re: John_Kunkel]
#2263889
03/05/17 07:42 PM
03/05/17 07:42 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Have you had any luck finding air filter to carb gaskets? ( besides making one?).... I suck at making them.....
[Re: minivan]
#2263904
03/05/17 08:12 PM
03/05/17 08:12 PM
RapidRobert
The circular gasket? I just cut/snip/add as required for the circle I need & join the ends & glue em with a touch of super glue on the bottom of where the ends meet so above that point is still pliable & can be lightly crushed for a good seal.
[Re: minivan]
#2263914
03/05/17 08:25 PM
03/05/17 08:25 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Have you had any luck finding air filter to carb gaskets? ( besides making one?).... I suck at making them..... http://www.jegs.com/i/Fel-Pro/375/2102/10002/-1Looks like it's Felpro p/n 2102.
[Re: ScottSmith_Harms]
#2263934
03/05/17 09:02 PM
03/05/17 09:02 PM
John_Kunkel
Rio Linda, CA
If you use an Edelbrock 1405/06 it's no problem at all. It is a 1406. What's unique about them compared to others?
[Re: Jeremiah]
#2263968
03/05/17 09:59 PM
03/05/17 09:59 PM
minivan
Eugene, Oregon
Have you had any luck finding air filter to carb gaskets? ( besides making one?).... I suck at making them..... http://www.jegs.com/i/Fel-Pro/375/2102/10002/-1Looks like it's Felpro p/n 2102. Thank you...
[Re: BSB67]
#2263969
03/05/17 10:01 PM
03/05/17 10:01 PM
minivan
Eugene, Oregon
I don't know the answer to your question. But is there a later model air cleaner base that will fit your air cleaner top with the larger opening? I have both 67 and 68 air cleaner bases and have had luck solving this problem by switching bases. Yes their are.. I found one at a wrecking yard in case I want to use a newer carb on my car with my stock Air cleaner...
[Re: 62maxwgn]
#2264806
03/07/17 12:27 PM
03/07/17 12:27 PM
minivan
Eugene, Oregon
Have you had any luck finding air filter to carb gaskets? ( besides making one?).... I suck at making them..... http://www.jegs.com/i/Fel-Pro/375/2102/10002/-1Looks like it's Felpro p/n 2102. You can get the "correct" gasket here. http://quadrajetparts.com/misc-gaskets-seals-c-299_130_134_135.html That's an interesting website.. TY
[Re: John_Kunkel]
#2266313
03/09/17 05:56 PM
03/09/17 05:56 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I have 750 carters with the old AFB tops on them.
[Re: JohnRR]
#2266442
03/09/17 10:11 PM
03/09/17 10:11 PM
RapidRobert
John you didn't happen to save the 750 tops did you?
[Re: RapidRobert]
#2268669
03/13/17 03:43 PM
03/13/17 03:43 PM
JohnRR
U.S.S.A.
John you didn't happen to save the 750 tops did you? No I bought them that way , sorry.
[Re: John_Kunkel]
#2268752
03/13/17 06:09 PM
03/13/17 06:09 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have 750 carters with the old AFB tops on them. Yes, they fit 600's, 750's and 800's. I build clones of all 3 sizes but for nearly anything streetable the 600's are plenty.
