Re: 71 cuda rocker moulding clip stud spacing
[Re: sixpackbird]
#2267331
03/11/17 12:35 PM
03/11/17 12:35 PM
Posts: 1,795 BC Canada
ogopogo
BC Canada
Attached are pics from sixpackbird (Mike) and here are some dimensions from an original car Alan Gallant kindly measured for me:
Holding a measuring tape along the rocker right where the trim goes. I hooked the tape in the gap between the rocker and heel of the fender....moving towards the rear of the car, the first pin is at 9”. There are five pins per side and each are spaced 9 3/4’’ apart . Studs are 11/16” or 3/4” with the tape hooked on,below the door opening
