Race Motor copper in oil n milkshake? #2263132
03/04/17 10:06 AM
03/04/17 10:06 AM
N.Y.
sixpacksteve Offline OP
N.Y.
my buddy purchased a race duster w/340 ran 10.70's he made 1 pass n checked oil had copper in oil. dropped oil changed out w/brad penn, ran it for 5 minutes checked oil and it looks like a milkshake. bearings for the copper i get, where would water be getting in. he pulled heads and No sign on head gaskets. ANY ideas?
Hell Hath No Fury Like Mine
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2263144
03/04/17 10:53 AM
03/04/17 10:53 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I've seen the cam bolt back out and punch a hole in the back of the water pump/timing cover.
Kevin
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2263151
03/04/17 11:10 AM
03/04/17 11:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My 340 cracked a cly wall and mixed coolant with the oil. Car still ran great. Too much coolant in the oil will wipe the bearings. The crack was so small I could not see it with my bare eye.
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2263212
03/04/17 01:38 PM
03/04/17 01:38 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Could be just the intake??? I don't know if it's copper or bronze that you are seeing. Bronze cam gears always leave a little showing in the oil.
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2263439
03/04/17 09:54 PM
03/04/17 09:54 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Cracked head or block? I had a 408 stroker built from mid 80s 360 and the heads had cracked.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2263629
03/05/17 01:04 PM
03/05/17 01:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
could be the timing cover, intake gasket, or crack in block.Watered down oil caused bearings to fail(the copper). Tear down and insp. time. wrench scope
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2263649
03/05/17 01:35 PM
03/05/17 01:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
the problem will be directly linked to your wallet.
Re: Race Motor copper in oil n milkshake? [Re: sixpacksteve] #2264200
03/06/17 10:27 AM
03/06/17 10:27 AM
Locomotion Offline
Locomotion  Offline
What's worse is did the seller know about the problem and had fresh oil in it when he sold it!
I've had a cam bolt back out, but it took a while before it cracked the cover. Also had cracked cylinder wall let water in.
