Advice on Crate Motor upgrade on Gen 2 Hemi #2260991
02/28/17 12:45 PM
02/28/17 12:45 PM
Utah in the Wasatch Mountains
Lucky Dart Offline OP
Group: Have purchased a 71 Challeger with a 472 Crate motor / 727TF combo.
Looking to upgrade to aluminum heads dual quad intake. Would appreciate your suggestions on sorceing parts. Edelbrock is an obvious "kit", but what others would be the question?
The long term plans would be procharged, water/methonal fuel injected upgrades. Getting set for those now.
Looking for 900hp in a street / strip car.
Currently 591hp 580tq N/A
Links to threads here and on other sights appreciated as well as suggestions!
Thanks in advance.
Clay
Re: Advice on Crate Motor upgrade on Gen 2 Hemi [Re: Lucky Dart] #2261005
02/28/17 01:04 PM
02/28/17 01:04 PM
P
Porter67 Offline
Porter67  Offline
P
Are you looking for an add on or a build to fit your needs?
I dont have much faith in mopar crate motors that have not been torn down and inspected from a quality control aspect.
Re: Advice on Crate Motor upgrade on Gen 2 Hemi [Re: Lucky Dart] #2261011
02/28/17 01:23 PM
02/28/17 01:23 PM
an8sec70cuda Offline
You could have Modern Cyl. head CNC port your existing heads. My MP heads are just aluminum versions of the cast iron heads you have...ported they flow 430 cfm and make somewhere close to 850 hp N/A on pump gas on my 572" motor.
Get a custom roller cam for it and put on a Stage V dual quad intake.
This is assuming the bottom end is in good condition and would be a hell of an upgrade over the standard crate motor.
Like EV2 said, those crate motors have a horrible reputation for build quality and have all kinds of issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Advice on Crate Motor upgrade on Gen 2 Hemi [Re: Lucky Dart] #2261013
02/28/17 01:28 PM
02/28/17 01:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Don't know whos crate it is but have NOT heard good things about "crates".
What CR is that engine at??Will it be intercooled?
1000 hp is very easy wit that cubic inch.
Will you do this on your own or do you have a machine shop?
Post some pictures of that bad boy whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Advice on Crate Motor upgrade on Gen 2 Hemi [Re: Lucky Dart] #2261154
02/28/17 06:03 PM
02/28/17 06:03 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The Edelbrock heads are probably the best choice, but a 472 is 4.25" bore. The Edelbrock intake valve won't open on a 4.25 bore unless you notch the bores, so you will have to take the engine out of the car and tear it all the way down.
2011 Drag Pak Challenger
Re: Advice on Crate Motor upgrade on Gen 2 Hemi [Re: Porter67] #2261159
02/28/17 06:12 PM
02/28/17 06:12 PM
I have heard the same for the crate motors....have them gone thru.
The motor was gone thru by the previous owner. Have dyno printouts, receipts, and images on the dyno.
So looking to add on. Aluminum heads to save weight and I don't really want the car down. Would rather gather parts and install. Keeping the car drive-able keeps me motivated.
Re: Advice on Crate Motor upgrade on Gen 2 Hemi [Re: hemi-itis] #2261160
02/28/17 06:22 PM
02/28/17 06:22 PM
Sketchy on posting images....here goes.
20160901_115725_resized
