Cheetah Shifter Question #226079
02/15/09 07:30 PM
02/15/09 07:30 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
I have a reverse pattern cheeteah shifter. I was wondering about adding an electric or air solonoid. I dont think I have the correct gate pattern as I have to pull the shifter towards me to put it in third gear. Is there another gate pattern that I can put on my shifter or do I need a new or different shifter?
Also what do guys like for solonoid shifters, brand? electric or air??
Re: Cheetah Shifter Question [Re: JandJ_Racing] #226080
02/15/09 08:09 PM
02/15/09 08:09 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Isn't the reverse or forward pattern shift set in the valve body?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Cheetah Shifter Question [Re: Adobedude] #226081
02/15/09 08:42 PM
02/15/09 08:42 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
With the Cheetah shifter there are two shift
pattern plates.
(A) Reverse pattern PRN123 (black plate)
(B) Manual forward pattern PRN321 (chrome plate)
These are the two plates that came with mine.
and the pattern is different between the two
on one the bottom position (1st or 3dr)are on
the left and on the other one it is on the
right.
Phil Saran Parker, Colorado
Re: Cheetah Shifter Question [Re: Phil Saran] #226082
02/15/09 10:32 PM
02/15/09 10:32 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I have a Cheetah Shifter on my CRT 727, but I ordered it with a reverse pattern valve body. I had my choice of plates...I used the forward pattern plate because I liked how it had a gate to keep me pulling it straight into 3rd from 1st.
Which I still do on occasion , I'm used to a ratchet shifter.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Cheetah Shifter Question [Re: Phil Saran] #226083
02/15/09 10:56 PM
02/15/09 10:56 PM
N
NITROUSN Offline
NITROUSN  Offline
N
pattern plates.
right.
There are more plates than that available. Call turbo action for the correct plate for your application. Dedenbear will sell you the correct air shift.
Re: Cheetah Shifter Question [Re: JandJ_Racing] #226084
02/15/09 11:10 PM
02/15/09 11:10 PM
Indiana
P
Pentastar440 Offline
P
Indiana
I too have a Cheetah shifter with reverse pattern. It would seem to me that an electric solenoid could be hooked to the shift light in order to set the rpm to shift. Then the solenoid could be used for the 1-2 shift, then pull the 2-3 shift manually. It's the 1-2 shift that comes so fast. I have had trouble with my hand pulling the shifter from 1st gear into 2nd on launch. An electric solenoid for the 1-2 shift would eliminate an accidental 1-2 shift on launch, the 2-3 shift is not a problem to pull manually. I too would like to hear other opinions.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Cheetah Shifter Question [Re: Pentastar440] #226085
02/15/09 11:25 PM
02/15/09 11:25 PM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
I got my shifter from Biondio, came complete with shifter, correct gate and two air solenoids to activate 1st to 2nd and 2nd to 3rd shifts. ACD makes on to I think.
Re: Cheetah Shifter Question [Re: sg1093] #226086
02/15/09 11:47 PM
02/15/09 11:47 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
my t a shifter dont work worth a crap with air goes to 3rd i bought a ppp shifter imo a million time better
Re: Cheetah Shifter Question [Re: Pentastar440] #226087
02/16/09 12:16 AM
02/16/09 12:16 AM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
That is what I did when I had an air shifted Cheetah...Shifted with the air for 1-2 and manually for 2-3
