Re: Cheetah Shifter Question
[Re: JandJ_Racing]
#226080
02/15/09 08:09 PM
02/15/09 08:09 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Isn't the reverse or forward pattern shift set in the valve body?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#226081
02/15/09 08:42 PM
02/15/09 08:42 PM
Posts: 396 California, USA
Phil Saran
California, USA
With the Cheetah shifter there are two shift pattern plates.
(A) Reverse pattern PRN123 (black plate) (B) Manual forward pattern PRN321 (chrome plate)
These are the two plates that came with mine. and the pattern is different between the two on one the bottom position (1st or 3dr)are on the left and on the other one it is on the right.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#226082
02/15/09 10:32 PM
02/15/09 10:32 PM
Adobedude
New Mexico
I have a Cheetah Shifter on my CRT 727, but I ordered it with a reverse pattern valve body. I had my choice of plates...I used the forward pattern plate because I liked how it had a gate to keep me pulling it straight into 3rd from 1st. Which I still do on occasion ![](/ubbthreads/images/graemlins/shock.gif) , I'm used to a ratchet shifter.
[Re: Phil Saran]
#226083
02/15/09 10:56 PM
02/15/09 10:56 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
There are more plates than that available. Call turbo action for the correct plate for your application. Dedenbear will sell you the correct air shift.
[Re: Pentastar440]
#226087
02/16/09 12:16 AM
02/16/09 12:16 AM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
I too have a Cheetah shifter with reverse pattern. It would seem to me that an electric solenoid could be hooked to the shift light in order to set the rpm to shift. Then the solenoid could be used for the 1-2 shift, then pull the 2-3 shift manually. It's the 1-2 shift that comes so fast. I have had trouble with my hand pulling the shifter from 1st gear into 2nd on launch. An electric solenoid for the 1-2 shift would eliminate an accidental 1-2 shift on launch, the 2-3 shift is not a problem to pull manually. I too would like to hear other opinions.
That is what I did when I had an air shifted Cheetah...Shifted with the air for 1-2 and manually for 2-3
