Power windows? #2258931
02/24/17 09:17 PM
02/24/17 09:17 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
Anyone put power windows in their car? I've got a 71 Dart that I was tossing the idea of power windows around. Looking for suggestions for kits or parts to do this.
Re: Power windows? [Re: 80arrow] #2259403
02/25/17 07:01 PM
02/25/17 07:01 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Yes I installed power windows in my 56 Plymouth Belvedere...and couldn't be happier that I did..Sorry I don't have pictures.. But I did it the back yard way , and they work great !!!I only did the front windows..I had a doner car with power windows.. ( 1987 Chry 5 th ave.).swapped regulaters with the power unit , I had to shorten the length of the geared arm and they work fine . done 7 years ago , still ticking..My white and gold 56 has been on here many times, you may have seen it.. but due to a computer crash and hacking I lost everything..It was a very easy job ..Sorry I can't be of more help..
Re: Power windows? [Re: 80arrow] #2260459
02/27/17 01:42 PM
02/27/17 01:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I did ones like these on two cars and they work great. They are just a motor that actuates your stock manual crank regulators. They weigh next to nothing and have more torq than I can apply by hand with a manual crank. I used OEM power window switches and you would never know they're not stock except for the plastic caps that go over the hole in your door panel to cover the window crank splined stub. The kits I bough came with spacer bushings to space the regulator further into the door if you wanted to try to power window door panels without the hole although I never tried that.
Re: Power windows? [Re: 80arrow] #2260754
02/27/17 11:03 PM
02/27/17 11:03 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Daytona Turbo, where did you buy the kit, do you have a part number? I'm very interested in electric windows for my '72 Duster.
Re: Power windows? [Re: 80arrow] #2260962
02/28/17 11:55 AM
02/28/17 11:55 AM
Manitoba, Canada
Manitoba, Canada
If you ebay search "universal power window kit" scads of them show up.
Re: Power windows? [Re: 80arrow] #2260966
02/28/17 12:02 PM
02/28/17 12:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Put power windows in my 72 Dart, came out of a 79 Cordoba.
Don't be the exception.
Re: Power windows? [Re: DaytonaTurbo] #2261254
02/28/17 08:33 PM
02/28/17 08:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks like the whole kit is only about 50 bucks. Any tips on installation? Does any of the factory window hardware have to come apart, anything dangerous? It also says it can be turned with a window crank if the electric motor were to break. Thanks.
Re: Power windows? [Re: 80arrow] #2261566
03/01/17 12:03 PM
03/01/17 12:03 PM
Manitoba, Canada
Manitoba, Canada
All you do to install is remove your door interior panel, drill a couple holes in your door steel and bolt this thing right on. It comes with a variety of adapters to fit various manual crank window splines. You do not unbolt or touch any of the factory manual crank window regulator. If you google image search "universal power window install" you will see pics that make it clear. The drive cable is flexible so you can locate the motor where you have an opening in your door frame so it doesn't interfere with your interior panel.
I installed mine 10 years ago and still going strong. Back then, the basic model did not allow you to manually actuate the window with a crank, however the deluxe version did. I just got the regular version and have never had any sort of issues with it.
Re: Power windows? [Re: 80arrow] #2261571
03/01/17 12:22 PM
03/01/17 12:22 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Great info thanks DaytonaTurbo!
Re: Power windows? [Re: 80arrow] #2261776
03/01/17 06:57 PM
03/01/17 06:57 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Re: Power windows? [Re: 80arrow] #2261888
03/01/17 10:28 PM
03/01/17 10:28 PM
8
80arrow Offline OP
80arrow  Offline OP
Thanks Aero426, looks like I'll be getting this for my car. Thanks to everyone else for the input.
Re: Power windows? [Re: 80arrow] #2262140
03/02/17 12:56 PM
03/02/17 12:56 PM
moparx Online content
moparx  Online Content
several years ago i sold a member here this exact kit [if not, it was pretty darn close !]. they have come WAY down in price today from what they once were ! eek
beer
Re: Power windows? [Re: 80arrow] #2262145
03/02/17 01:07 PM
03/02/17 01:07 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
you gotta see the red green show where he makes the old dodge vans windows go up and down with a power drill----there must be some duct tape in there as well....
Re: Power windows? [Re: savoy64] #2262153
03/02/17 01:18 PM
03/02/17 01:18 PM
red green is my IDOL ! laugh2
beer
Re: Power windows? [Re: 80arrow] #2451401
02/13/18 09:46 PM
02/13/18 09:46 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Update, I finally tried this kit on my Duster. No Bueno.
Motors don't have enough power to move the window, even after lubing everything.
I was really hoping these would work.
Re: Power windows? [Re: 80arrow] #2451402
02/13/18 09:47 PM
02/13/18 09:47 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
By the way, even if I hold the motor and track perfectly straight it doesn't work. Moves window real slow a couple inches and stops.
Re: Power windows? [Re: 80arrow] #2451417
02/13/18 10:30 PM
02/13/18 10:30 PM
Manitoba, Canada
Manitoba, Canada
Something must be wrong. I installed a set of these on a 87 dodge daytona and the windows in that car were always tough to roll by hand. Even in winter when the windows would freeze to the seals they had enough jam to break them free where I had a tough time doing it by hand.
Have you tried hooking the motors directly to a known good battery? I wonder if you have an issue with a switch or wiring or bad motors.
Re: Power windows? [Re: 80arrow] #2451448
02/13/18 11:18 PM
02/13/18 11:18 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
install relays
Re: Power windows? [Re: 80arrow] #2451450
02/13/18 11:22 PM
02/13/18 11:22 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I did use a relay. What brand motors did you use? Mine are cheapo ebay. Was only $40 for the whole kit for both doors.
I'm guessing the motors are junk.
Re: Power windows? [Re: 80arrow] #2451451
02/13/18 11:23 PM
02/13/18 11:23 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Battery is known good too.
