ngk spark plugs #225965
02/15/09 05:25 PM
02/15/09 05:25 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
I am about 13.5-1 on a 500 inch motor. Ngk R5672A-9? Or R5672-8? (Indy Head) Which plug is colder?
Re: ngk spark plugs [Re: JandJ_Racing] #225966
02/15/09 05:33 PM
02/15/09 05:33 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
I use the R5672A-9 in my 495 Indy head motor
Re: ngk spark plugs [Re: MOPARCHAS] #225967
02/15/09 05:48 PM
02/15/09 05:48 PM
500 ci 13.2 compression 5672A-8
never fouled a plug with a crossram nevertheless
Re: ngk spark plugs #225968
02/15/09 05:49 PM
02/15/09 05:49 PM
the 9 is colder but its not correct for your application
Re: ngk spark plugs [Re: JandJ_Racing] #225969
02/15/09 05:59 PM
02/15/09 05:59 PM
NC
440Jim Offline
440Jim  Offline
NC
My 511 CID (4.250" stroke) is 13.5 CR with Indy 440-1 heads. I have run both NGK R5672A-8 and an Autolite that is equal to a -9. Both were fine, the -9 is colder, but the the -8 wasn't too hot in my motor. But I was running E-85 last year. The last race of the season I put the gas carb back on and ran 110 with the AR3933 (-9 heat range) plugs and they looked fine.
IMO, this is the borderline between the two. I put about 25 passes on each set in 2008. I didn't race much last year.
In 2007 with my MP Stage VI heads and 13.2 CR (larger combustion chamber), I ran nothing but -8 plugs. No way a -9 was needed.
Re: ngk spark plugs [Re: 440Jim] #225970
02/15/09 06:26 PM
02/15/09 06:26 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
autolite man here ar3932 on nos, ar3934 on motor 15 to 1
Re: ngk spark plugs [Re: rtstreet] #225971
02/15/09 06:32 PM
02/15/09 06:32 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
13.4:1 in my triple nickel has had nothing but AR3932's with over 400 passes at 1000hp.
You will be fine with a -9 plug just make sure you have room for 5672 as it has projected tip. That is worth a little power in itself.
Re: ngk spark plugs #225972
02/15/09 07:24 PM
02/15/09 07:24 PM
Way North Illinois
Way North Illinois
Ok What is?
Re: ngk spark plugs [Re: JandJ_Racing] #225973
02/15/09 07:39 PM
02/15/09 07:39 PM
Ok What is?
go with the 5672A-8 if you have flat top pistons if you have domes you'll need the 5671A-8 non projected tip and you'll need to index them.
Re: ngk spark plugs #225974
02/15/09 07:47 PM
02/15/09 07:47 PM
Way North Illinois
Way North Illinois
Ok What is?
10-4 got it thank you Flat tops by the way.
