My 511 CID (4.250" stroke) is 13.5 CR with Indy 440-1 heads. I have run both NGK R5672A-8 and an Autolite that is equal to a -9. Both were fine, the -9 is colder, but the the -8 wasn't too hot in my motor. But I was running E-85 last year. The last race of the season I put the gas carb back on and ran 110 with the AR3933 (-9 heat range) plugs and they looked fine.
IMO, this is the borderline between the two. I put about 25 passes on each set in 2008. I didn't race much last year.
In 2007 with my MP Stage VI heads and 13.2 CR (larger combustion chamber), I ran nothing but -8 plugs. No way a -9 was needed.
