Hows this cam for my combo? 528 hemi #2258930
02/24/17 09:16 PM
02/24/17 09:16 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Grabbed this cam for half its original cost. Brand new solid flat tappet Bullet. Looks like a custom cam, but wasnt made for my combo. Has Ultradyne NF57 lobes intake and exhaust. (Full specs in the pic attachment)
Car is all steel a body, fun only street car.
528 Hemi
Unported Indy/Canfields heads, oem rockers
4.5bore, 4.150crank
4:56 gear, 4500 converter (may change conv later)
10.7 compression
tunnel ram w custom aed carbs
How fast will it be? Would you get a hotter cam?
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2259163
02/25/17 11:48 AM
02/25/17 11:48 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Duration seems pretty short for a 500ninch motor. bump
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2259195
02/25/17 12:34 PM
02/25/17 12:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
That's very similar to my Ray Barton spec'd cam. Mine is a flat solid 565/547 with 250 @ .050 in at 111*. My engine is 540" with MCH ported edelbrocks fed by the dual plane Indy intake and a 1050 Dominator.
It idles at 850 and made 697hp @ 6,800 on the engine dyno.
How much cam to run in these hot street engines comes down to how much horsepower do you want to make and how rough an idle and loss of drive-ability are you willing to put up with to get there. Your converter and gear will help to offset those issues if you go with a bigger cam.
How fast your car will be will largely depend on your tires/suspension. Hooking on the street is a real challenge with anything close to 700hp. Street tires are useless, drag radials are a bare minimum, and slicks likely necessary for all-out blasts.
For my needs, this is a good combo. The idle is bumpy enough to sound like a Hemi but the idle and off idle is not a pain to deal with while driving around. And 700 ponies moves the Cuda right along.
Master, again and still
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2259381
02/25/17 06:17 PM
02/25/17 06:17 PM
You bought it to use so put it in and degree it up
As far how fast will it be will be determined by you on the tuning and how good the chassis works work shruggy
What year, brand and weight A body ?
Re: Hows this cam for my combo? 528 hemi [Re: Cab_Burge] #2259452
02/25/17 08:51 PM
02/25/17 08:51 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
1972 demon, full interior, all steel. Never weighed it.
Id be willing to order a new cam if needed.
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2259467
02/25/17 09:27 PM
02/25/17 09:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What are your goals for this combo?
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2259615
02/26/17 01:56 AM
02/26/17 01:56 AM
Let me emphasize heavily, 426 hemi motor in a A body needs all the help you can provide it on traction, traction will determine how quick and how fast your car will go, not the power of the motor work shruggy
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2259808
02/26/17 02:23 PM
02/26/17 02:23 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Good street/strip cam for 528"Hemi,at pump gas C/R for a A-body with 3.73/4.10 gear and 3800/4500 converter.Big tires and 4.30+- gears can produce some excellent ETs.We used similar cam profiles with great success.You can always adjust bottom end power with cam timing.
Re: Hows this cam for my combo? 528 hemi [Re: B G Racing] #2260393
02/27/17 12:14 PM
02/27/17 12:14 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Bob, can I ask where you would install that cam? Im only running 28" drag radials. Would you retard it?
Re: Hows this cam for my combo? 528 hemi [Re: DaveRS23] #2260394
02/27/17 12:17 PM
02/27/17 12:17 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Sorry I missed your question..no real goals I suppose. Would be nice to run low 10's. But probably need a converter change
Re: Hows this cam for my combo? 528 hemi [Re: Hot 340] #2260929
02/28/17 09:31 AM
02/28/17 09:31 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We would install it at 108 or straight up at 110.Cam install centerline depends on the complete combo,engine and chassis.
Re: Hows this cam for my combo? 528 hemi [Re: B G Racing] #2261402
03/01/17 12:22 AM
03/01/17 12:22 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
up thanks Bob
