downsides to using a thick head gasket #2258445
02/24/17 12:42 AM
02/24/17 12:42 AM
Medina, OH
dart440_72 Offline OP
Medina, OH
What are the downsides to using a thick head gasket. Long story short, I needed to replace my pistons. I have 64cc Indy SR heads on a 500" B block and want to get my compression down to 10:1. The piston manufacturers are saying with a 1009 fel pro, there is no way to get the compression down that low and retain strength in the piston itself. So the question is about going to a thicker head gasket. Are there any significant downsides?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: downsides to using a thick head gasket [Re: dart440_72] #2258470
02/24/17 01:22 AM
02/24/17 01:22 AM
I would call a different piston maker to see if they can make you a reverse dome piston to get the compression ratio you want in your motor scope
I have used them, reverse dome pistons, many times to get the compression ratio where I wanted it with 400 blocks and 4.300 stroke shruggy
As far as thicker head gaskets, I have used .080 copper head gaskets in the past to make the compression ratio the customer wanted instead of buying new pistons realcrazy
If your motor has decent quench now with a .047 thick head gasket and you switch to a bigger bore and thicker head gasket you will probably loose any quench you have now work
Re: downsides to using a thick head gasket [Re: dart440_72] #2258483
02/24/17 01:37 AM
02/24/17 01:37 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That 1009 probably overhangs the bore anyway. Not good.
My 493 came in at 8.97:1 with IIRC a 34cc reverse dome Ross piston OOTB RPM's and a .039" gasket.
I had to use the regular FelPro gasket as the 1009 overhung the bore because of the chamfer at the top. At the time it was the only other .039 gasket I could get that had an acceptable bore size.
Kevin
Re: downsides to using a thick head gasket [Re: dart440_72] #2258495
02/24/17 01:56 AM
02/24/17 01:56 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Call Cometic
Re: downsides to using a thick head gasket [Re: dart440_72] #2258506
02/24/17 02:13 AM
02/24/17 02:13 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I use a .052" thick Felpro. Don't know what .013" difference will buy you.
Cometics are MLS and require a special deck finish.
I've often wondered if there would be any harm in stacking 2 or 3 stock .019" gaskets !! I could use the extra room in the quench area.
Re: downsides to using a thick head gasket [Re: dart440_72] #2258507
02/24/17 02:16 AM
02/24/17 02:16 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Inefficient. twocents
Pouring Octane Boost or Av Gas to it is a better, cheaper, and less headache than replacing head gaskets.
Beyond my understanding, but a different cam can bleed compression off.
You said "long story short", but why do you need to replace pistons? What is the problem?
Mo' Farts
Moderated by "tbagger".
Re: downsides to using a thick head gasket [Re: dart440_72] #2258650
02/24/17 12:34 PM
02/24/17 12:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2
a different cam can bleed compression off at cranking speed. The effect decays as RPM rises, and it's completely gone when you get to your torque curve.
Boffin Emeritus
Re: downsides to using a thick head gasket [Re: dart440_72] #2258748
02/24/17 03:13 PM
02/24/17 03:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think it would be helpful if we knew what the current cr and gasket thickness is. We're just assuming its a 1009 gasket and a .045 quench.
Re: downsides to using a thick head gasket [Re: Grizzly] #2258754
02/24/17 03:25 PM
02/24/17 03:25 PM
Medina, OH
Medina, OH
The cylinder walls ended up getting scored pretty bad. They were able to sonic check the block and save it with a bore job. I had 13.5:1's in it, but wanted to step it down to use pump gas with some nitrous every once in a while.
Re: downsides to using a thick head gasket [Re: dart440_72] #2258758
02/24/17 03:33 PM
02/24/17 03:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just for grins and giggles what are you calling think?? Also FWIW why do you think you need to be at 10-1 for pump gas?
Re: downsides to using a thick head gasket [Re: dart440_72] #2258788
02/24/17 04:18 PM
02/24/17 04:18 PM
Guitar Jones Offline
I have .120 thick Cometic gaskets in my small block. Had to do it for expediency and cost. Domed pistons with a small chamber W5 just didn't work. Any way, it made intake sealing a challenge but other than that it runs fine with no issues.
Re: downsides to using a thick head gasket [Re: dart440_72] #2258862
02/24/17 06:33 PM
02/24/17 06:33 PM
Idaho
LaRoy Engines Offline
Idaho
I think you are talking to the wrong piston people. Ross made me some 4.500" bore pistons with a 55cc dish, strong enough to throw some boost at them.
Re: downsides to using a thick head gasket [Re: LaRoy Engines] #2258873
02/24/17 06:57 PM
02/24/17 06:57 PM
dogdays Offline
dogdays  Offline
Here's another idea...E85. Your engine would be perfect for running the stuff.
With correct squish and aluminum heads you should be able to run more than 10.0:1.
500 inch V8 has 1025cc swept volume.
13.5:1 has 82cc above piston
12.5:1 has 89cc above piston
12.0:1 has 93cc above piston
11.5:1 has 98cc above piston
10.5:1 has 108cc above piston
With correct squish and engine optimized I'd shoot for 11.5:1 on pump gas. You probably have a pretty big cam in the motor and that might allow even higher. you're only looking at 11cc from 13.5 to 12.0.
Any good piston manufacturer should be able to come up with a piston that fills the bill. Or if they don't have a forgoing blank that could be machined to work, someone else does.
R.
Re: downsides to using a thick head gasket [Re: dart440_72] #2259008
02/25/17 12:25 AM
02/25/17 12:25 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Ok, so you are at overbore anyway:
get new pistons with some more dish than what you have,
Ask for quench pads to match your heads,
and call it good. up
Run the thinnest head gasket you can get away with. twocents
Unless these heads are open-chamber?
Mo' Farts
