downsides to using a thick head gasket
#2258445
02/24/17 12:42 AM
02/24/17 12:42 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
What are the downsides to using a thick head gasket. Long story short, I needed to replace my pistons. I have 64cc Indy SR heads on a 500" B block and want to get my compression down to 10:1. The piston manufacturers are saying with a 1009 fel pro, there is no way to get the compression down that low and retain strength in the piston itself. So the question is about going to a thicker head gasket. Are there any significant downsides?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: downsides to using a thick head gasket
[Re: dart440_72]
#2258470
02/24/17 01:22 AM
02/24/17 01:22 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
I would call a different piston maker to see if they can make you a reverse dome piston to get the compression ratio you want in your motor I have used them, reverse dome pistons, many times to get the compression ratio where I wanted it with 400 blocks and 4.300 stroke As far as thicker head gaskets, I have used .080 copper head gaskets in the past to make the compression ratio the customer wanted instead of buying new pistons If your motor has decent quench now with a .047 thick head gasket and you switch to a bigger bore and thicker head gasket you will probably loose any quench you have now
[Re: dart440_72]
#2258483
02/24/17 01:37 AM
02/24/17 01:37 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
That 1009 probably overhangs the bore anyway. Not good.
My 493 came in at 8.97:1 with IIRC a 34cc reverse dome Ross piston OOTB RPM's and a .039" gasket.
I had to use the regular FelPro gasket as the 1009 overhung the bore because of the chamfer at the top. At the time it was the only other .039 gasket I could get that had an acceptable bore size.
Kevin
[Re: dart440_72]
#2258507
02/24/17 02:16 AM
02/24/17 02:16 AM
Posts: 6,004 Salem
Grizzly
Moparts Proctologist
Salem
So the question is about going to a thicker head gasket. Are there any significant downsides? Inefficient. Pouring Octane Boost or Av Gas to it is a better, cheaper, and less headache than replacing head gaskets. Beyond my understanding, but a different cam can bleed compression off. You said "long story short", but why do you need to replace pistons? What is the problem?
Mo' Farts
Moderated by "tbagger".
[Re: dart440_72]
#2258650
02/24/17 12:34 PM
02/24/17 12:34 PM
Posts: 4,209 New York
polyspheric
New York
you will probably loose any quench you have now X2
a different cam can bleed compression off at cranking speed. The effect decays as RPM rises, and it's completely gone when you get to your torque curve.
Boffin Emeritus
[Re: Grizzly]
#2258754
02/24/17 03:25 PM
02/24/17 03:25 PM
dart440_72
Medina, OH
So the question is about going to a thicker head gasket. Are there any significant downsides? Inefficient. Pouring Octane Boost or Av Gas to it is a better, cheaper, and less headache than replacing head gaskets. Beyond my understanding, but a different cam can bleed compression off. You said "long story short", but why do you need to replace pistons? What is the problem? The cylinder walls ended up getting scored pretty bad. They were able to sonic check the block and save it with a bore job. I had 13.5:1's in it, but wanted to step it down to use pump gas with some nitrous every once in a while.
[Re: dart440_72]
#2258758
02/24/17 03:33 PM
02/24/17 03:33 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Just for grins and giggles what are you calling think?? Also FWIW why do you think you need to be at 10-1 for pump gas?
[Re: dart440_72]
#2258788
02/24/17 04:18 PM
02/24/17 04:18 PM
Guitar Jones
I have .120 thick Cometic gaskets in my small block. Had to do it for expediency and cost. Domed pistons with a small chamber W5 just didn't work. Any way, it made intake sealing a challenge but other than that it runs fine with no issues.
[Re: dart440_72]
#2259008
02/25/17 12:25 AM
02/25/17 12:25 AM
Posts: 6,004 Salem
Grizzly
Salem
Ok, so you are at overbore anyway: get new pistons with some more dish than what you have, Ask for quench pads to match your heads, and call it good. Run the thinnest head gasket you can get away with. Unless these heads are open-chamber?
Mo' Farts
