Procharger on a Gen 2 Hemi? #2258440
02/24/17 12:34 AM
02/24/17 12:34 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
Thinking about doing a Procharger on my Hemi build but would like to stay with a belt drive system.
Has anyone here installed a kit on there motor?
Would like to see some pictures so I have an idea of what I'd need to do it and what size procharger did you use?
Thanks for any and all info
Kevin
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2258490
02/24/17 01:48 AM
02/24/17 01:48 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I seen one on a street driven Barracuda a number of years ago. Of course the owner said it was fast, what else would he say , LOL I'd also like to hear about that set up.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2258807
02/24/17 04:53 PM
02/24/17 04:53 PM
regina sask
N
nitrousr Offline
nitrousr  Offline
N
regina sask
We have a f3r 131 on a gen 2 hemi in the duster. Will try and post pics later or search under my user name theres a few on here already.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2258843
02/24/17 06:04 PM
02/24/17 06:04 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Done several with good results.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2258947
02/24/17 09:58 PM
02/24/17 09:58 PM
ONTARIO,CANADA
ONTARIO,CANADA
Hey Rich
Have you done any with EFI?
Kevin
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2258972
02/24/17 11:00 PM
02/24/17 11:00 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Five so far. Much easier with EFI. The carb motor in the pic was very sensitive to the intake elbow. I ended up not using what's in the photo. BTW, I kept the displacement down because of the small blower size. It all had to fit ... lol.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259011
02/25/17 12:26 AM
02/25/17 12:26 AM
ONTARIO,CANADA
ONTARIO,CANADA
What would you use with a motor that 600ci?
I'd like to be able to be competitive in a class at Brainerd International Raceway in Minnesota.
The class is king of the street but I'd still like to be able to go to the local car show once or twice with my car.
Plus you need to complete a 10 mile drive to be able to compete in the class
Kevin
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259113
02/25/17 06:33 AM
02/25/17 06:33 AM
the Netherlands
dutchrunner Offline
dutchrunner  Offline
the Netherlands
Curious also.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259250
02/25/17 02:06 PM
02/25/17 02:06 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
For that many cubes you'd need an F2 or an F3R. Streetability comes from the tune and I have seen several F2 customers drive their cars on the street without problems. Of course this was with EFI and I admit, I'm biased... LOL
One guy runs gas on the street and switches over to methanol for the track.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259298
02/25/17 03:50 PM
02/25/17 03:50 PM
ONTARIO,CANADA
ONTARIO,CANADA
Ok and since this a new build car and motor I was planning on EFI from the start.
So what size F2 or F3 might fit under a carbonfiber hood
Kevin
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259312
02/25/17 04:23 PM
02/25/17 04:23 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I can't help you with that. Every installation is different and these larger superchargers are tough to fit in a stock hood configuration. Talk to Procharger and see what they say.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259338
02/25/17 05:10 PM
02/25/17 05:10 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Kevin
I know its not a Hemi but on my small block I could keep everything under a flat hood. I used a 90 degree elbow from 6061.com to mount my throttle body to. I had to have an inch machined off the top of my Indy intake to get everything to work. I could also fit my F2 side slinger in the engine bay with the stock inner fenders. On a Hemi I'm not sure since they are so much wider. A F2 isn't really that much bigger in size then a F1R.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259353
02/25/17 05:50 PM
02/25/17 05:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Used to be ATI's brackets were not strong enough, must either make new from heavy plate stock or add doubler plates.
Boffin Emeritus
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2259446
02/25/17 08:39 PM
02/25/17 08:39 PM
ONTARIO,CANADA
ONTARIO,CANADA
Well I guess there's only one way to find out......just build it!!!
Kevin
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2260187
02/26/17 11:42 PM
02/26/17 11:42 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Kevin
I run a F2 on my 440, it's a cog drive sideslinger, the F3 would be gear drive due to it's size. I run a 950 blow thru non intercooled but have AIS meth injection. My inner fenders are long gone and I have to use a lift off six pack hood cause of the clearance issues.I drive it on the street and run it at the track.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2260218
02/27/17 12:34 AM
02/27/17 12:34 AM
ONTARIO,CANADA
ONTARIO,CANADA
Would you have pictures of your engine bay.
I'd like to see how the F2 fit and maybe give me some ideas
Kevin
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2260335
02/27/17 09:51 AM
02/27/17 09:51 AM
the Netherlands
dutchrunner Offline
dutchrunner  Offline
the Netherlands
Loads of pix on internet of Gen2 + F2 in E-B bodies.
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2260346
02/27/17 10:51 AM
02/27/17 10:51 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Had to cut my inner fender with a f2
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2260787
02/27/17 11:40 PM
02/27/17 11:40 PM
Shannonville, Ont
Shannonville, Ont
Not sure how to post pics.... google Dodge Coronet F2 Procharger, there's lots there to choose from, look for Viper Snakeskin Green 68 Coronet
Re: Procharger on a Gen 2 Hemi? [Re: 604 Hemi GTX] #2260916
02/28/17 06:34 AM
02/28/17 06:34 AM
ONTARIO,CANADA
ONTARIO,CANADA
Did you post a YouTube video of your car?
https://m.youtube.com/watch?v=LiW7MkwNZ1A
