Re: 75 Power Wagon rear brakes.
[Re: Kern Dog]
#2258464
02/24/17 01:16 AM
02/24/17 01:16 AM
Posts: 10,641 Freeport IL USA
poorboy
Freeport IL USA
One of the advantages of buying a Dodge, back in the "old" days was that Dodge would automatically do parts upgrades as better parts or systems became available, and not wait until the end of the year model change to incorporate those changes, like most of their competitors did.
One of the problems with Dodge trucks was that they made changes during a production year rather then waiting until the end of the model year. Kind of a double edge sward. Often you didn't know which version you had until you took it apart. Its a really big problem on bigger trucks and RV chassis.
The biggest problem with the Dodge process is that there could have been more then 1 change in a model year! Maybe the "new and improved" wasn't so "improved" or there wasn't enough supply to meet the demand. Dodge may have reverted back to the original design, or they may have installed another new design. Are we having fun yet?
I believe someone at some warehouse found a stash of Dodge brake drums & parts from a short run model year, and decided to sell them off as an option for that year, and everyone that deals with that warehouse offered the "optional" parts.
The one saving grace of the Dodge process, is that usually, the "new" and the "old" parts are interchangeable as a unit. The change took place on the assembly line, so as the parts came down the line, the old parts were converted to the new parts, which means a person could resort back to the old parts (or convert to the new parts) by changing whatever parts were required per unit. The biggest problem is, you have to figure out what all needs to be changed to make the "other parts" work. Gene
[Re: Kern Dog]
#2258812
02/24/17 05:07 PM
02/24/17 05:07 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I put a complete "full floating axle" from an '84 under my '76 3/4 ton, when the bearings failed. Lack of maintenance on my part. Lucked out and got a better ratio in the deal.
I have mechanical Aptitude. I can screw up anything.
[Re: Kern Dog]
#2259668
02/26/17 08:12 AM
02/26/17 08:12 AM
Posts: 5,947 ohio
ruderunner
ohio
Nice truck but I was hoping for pics of the hub and drum.
Angry white pureblood male
