71 'Cuda 8 3/4" rear end inspection mark I.D help needed #2256512
02/20/17 11:56 AM
02/20/17 11:56 AM
Akron, ohio
76orangewagon Offline OP
Akron, ohio
I decided to clean off 46 years of grease and road grime on my 1971 340 'Cuda yesterday and found several paint inspection marks, I found some slight remains of a yellow axle code on the left axle tube, Orange and white paint daubs on the bottom of the carrier, A yellow "G" to the right of the housing pumpkin but I cannot make out the white marks on the pumpkin itself. It looks like a sideways "J" but the other mark below that looks like it might have been a tilted "A" but some of it is missing, I know no two cars were the same but has anybody seen similar marks that will help me figure out how those marks could have looked when applied ?
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2257628
02/22/17 05:12 AM
02/22/17 05:12 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted By 76orangewagon
a yellow axle code on the left axle tube?
On my car, that axle code was printed on the build sheet.
See:
https://board.moparts.org/ubbthreads/show...amp;Search=true
https://board.moparts.org/ubbthreads/show...e=0#Post7872418
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
https://www.google.com/search?q=8-3/4+rear+end+paint+marks&rlz=1C1VFKB_enUS656__656&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwju1-i1q6rOAhVJlx4KHf2SAc4QsAQIHQ&biw=1280&bih=923#tbm=isch&q=8-3%2F4+a-body+rear+end+paint+daubs
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2257644
02/22/17 08:31 AM
02/22/17 08:31 AM
Akron, ohio
Akron, ohio
Yes mine is also....019. Those I can see but the ones on the pumpkin are the only ones I can't completely see.
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2258087
02/23/17 04:39 AM
02/23/17 04:39 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Any change your car is early production?
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: Morty426] #2258269
02/23/17 06:20 PM
02/23/17 06:20 PM
Akron, ohio
Akron, ohio
My SPD is 430, so it is a late production.
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2258281
02/23/17 07:08 PM
02/23/17 07:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's fairly late.
My guess is the letters indicated a gate position. The rear end was to be in gate J and then gate G OR the other way around. The only a guess.
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2258927
02/24/17 09:10 PM
02/24/17 09:10 PM
Akron, ohio
Akron, ohio
,A guess is better than what I've gotten anywhere else, I guess I can reproduce the marks I can see like the J and G and skip the other mark on the pumpkin or just recreate it as it currently looks.
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2259047
02/25/17 01:34 AM
02/25/17 01:34 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
My spd was 526, date on rear is 3620, I've got other late 70 stuff, but also late 69 stuff, including my block.... these were some of the markings
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: shakerjoe] #2259055
02/25/17 01:42 AM
02/25/17 01:42 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
More
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: shakerjoe] #2259059
02/25/17 01:55 AM
02/25/17 01:55 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
2 more
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2259261
02/25/17 02:28 PM
02/25/17 02:28 PM
Akron, ohio
Akron, ohio
Thanks Shakerjoe,
I have some of the similar markings on the carrier although mine are a little harder to read, I'll try to clean it a little better once its removed from the car. I assume you didn't have any markings on the housing or pumpkin?
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2259453
02/25/17 08:55 PM
02/25/17 08:55 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
nothing other than what I posted, but there was a tiny blotch of what looked like pink on the driver axle tube, didn't know what it was so I didn't duplicate it when I had the rear rebuilt
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2259484
02/25/17 10:01 PM
02/25/17 10:01 PM
BS23H1B Offline
BS23H1B  Offline
I don't know if it will help you out but here are some markings off a 70Cuda spd 413
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2259486
02/25/17 10:04 PM
02/25/17 10:04 PM
BS23H1B Offline
BS23H1B  Offline
More (70 Cuda)
Re: 71 'Cuda 8 3/4" rear end inspection mark I.D help needed [Re: 76orangewagon] #2260770
02/27/17 11:18 PM
02/27/17 11:18 PM
Akron, ohio
Akron, ohio
I found this photo online from a 1971 'Cuda maybe my sideways "J" is a 4. Any thoughts ? it looks very close to mine(Bottom photo).
