360 magnum kickdown linkage? #225729
02/15/09 02:25 PM
02/15/09 02:25 PM
Grand Rapids, MI
Jim L Offline OP
super street
Jim L  Offline OP
super street
Grand Rapids, MI
What are you guys using for throttle cable/kickdown linkage brackets on your magnum engines? I'm using an airgap intake, 1/2 spacer and an Edelbrock AVS carb. Pics?
Re: 360 magnum kickdown linkage? [Re: Jim L] #225730
02/15/09 03:11 PM
02/15/09 03:11 PM
I've got a magnum headed LA block with an airgap and an edelbrock AVS.. using the bouchillion setup.. no pictures, but looks similiar to the setup on their website
http://www.bouchillonperformance.com/BPEtkdc.asp
got the throttle bracket / kickdown cable from them... install was easy. works well, looks good.
-j
Re: 360 magnum kickdown linkage? [Re: Jim L] #225731
02/16/09 08:59 AM
02/16/09 08:59 AM
NY usa
540challenger Offline
NY usa
I have the eddy sir gap on my magunm headed LA.
I took the stock bracket bent it to match the verital holes then went to the hardware store picked up some spacers and longer bolt. Work out well. I do have the 3 piece linkage so i had plenty of adjustment. this is on a 71 challenger
