Edlebrock D66 Dual Quad Intake Manifold????? #225705
02/15/09 02:15 PM
02/15/09 02:15 PM
Q
quick77rt Offline OP
Parts Problem
Parts Problem
Q
I cant seem to find much info, not even on the older posts here.
What I do find is they are semi rare, many currently are looking for one.
They say they are a good stroker intake because of its 1000-6500 plus operating range, good for a stroker.
So whats the deal on these manifolds....???????
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: quick77rt ] #225706
02/15/09 02:27 PM
02/15/09 02:27 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Mark,
I Haven't seen one in maybe 20 yrs....looked like a clone of the Eddie Chevy SB in line IIRC.....If I remember '66' is the year they came out (pre 340 days) so the port cross-sections will likely be 273/318 sized so I'm not sure how it would do on a stroker, (so the 1500-6500 would have been for a 273 so that would be about what idle, to 5000 on a 410" motor? ) maybe best suited to a nostalgia rod or a MILD stroker, can't imagine it working better on a big cube motor than a good single plane.
WIZE
In Car:
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: Streetwize] #225707
02/15/09 02:33 PM
02/15/09 02:33 PM
Q
Parts Problem
Parts Problem
Q
What im getting is its a decent mainfold because of the dual plane aspect give the stroker on the street an easier drive and at 6000 plus it dont give that much up and its a better pick then the offy?????
Whatever the case maybe it seems alot are looking for one of these....but now im thinking I might should of passed on this one
Oh well maybe just another good convo peice.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: quick77rt ] #225708
02/15/09 02:39 PM
02/15/09 02:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Modern single 4 intake and carb setups will trump nearly any vintage dual 4 setup in terms of max HP, especially a dual plane design dual 4. High rise tunnel rams might be a different story. That intake is a good "Wow the Burger King Crowd" intake, but IMO not the best choice for a stroker build.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: ScottSmith_Harms] #225709
02/15/09 02:45 PM
02/15/09 02:45 PM
Q
Parts Problem
Parts Problem
Q
Thats why I wont go to B King, if two fours make them say wow the must live in the chevy world......you know I like six-packs and alot of nitrous gear......
So why are some looking so hard for this intake and WHY did my dumbass pay so much....
I dont see a flip comming, I see a "I hope I can break even deal"
But I might try it just for kicks....im not looking for max output on the motor ive planned to put it on?????
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: quick77rt ] #225710
02/15/09 06:16 PM
02/15/09 06:16 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I`m pretty sure it is the small 273-318 port design. I knew a guy who had the intake welded and the ports were raised to the 340-360 size.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: mopars4ever] #225711
02/15/09 07:00 PM
02/15/09 07:00 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
D66 is for the 340/360. There was a separate manifold for the 273/318. I believe that one was a D64. The D66 is an excellent hot street manifold. True, an RPM will make more power but the D66 is still very very good. Its nice to be different- everyone runs a single carb. Back in the day more carbs was the ay to build more power. The D66 is better than the Offenhauser. The Offenhauser is still in production and available new. I have one. The Offy is a single plane and is meant for the 273. I was told that because it is a single plane it still works great on a 340/360. (An Edelbrock tech told me that) I will use mine with two 500 Eddies. I bet on a hot 360 if you compared the Perf RPM against the D66 with two good 500s that the power of the RPM would not be that much better than the D66. The D66 power range is similar to the RPM. Of course it doesnt have the air gap.
Keep old mopars alive.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: 2boltmain] #225712
02/15/09 07:01 PM
02/15/09 07:01 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Not mine.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: 2boltmain] #225713
02/15/09 07:02 PM
02/15/09 07:02 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Also not mine.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: quick77rt ] #225714
02/15/09 10:47 PM
02/15/09 10:47 PM
Indiana
P
Pentastar440 Offline
P
Indiana
This shows the D-66 as an early 273 intake. That would mean small ports.
www.victorylibrary.com/mopar/edel.htm
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: Pentastar440] #225715
02/16/09 01:30 AM
02/16/09 01:30 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Check out the selling price on this D66. Not sure how much the air cleaner effected the bidding. Still stupid money.
I've owned 3 over the last couple years and sold them in the $275-300 range.
http://cgi.ebay.com/ebaymotors/MOPAR-2X4...1QQcmdZViewItem
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: ChickMaggot] #225716
02/16/09 01:42 AM
02/16/09 01:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like the aircleaner is fiberglass...
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: 1_WILD_RT] #225717
02/16/09 03:54 AM
02/16/09 03:54 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What are those people on crack? That's a cool intake but you would have to be insane to pay that. You could do a complete 6 pack and have money left over...
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: DaytonaTurbo] #225718
02/16/09 06:16 AM
02/16/09 06:16 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Wow the D66 pricing is more than crazy. My Offy was $280 new in 2003. Edelbrock saw fit to bring back the RB 2x4 CH28 in the eraly 90s- It would be nice if they would do the same with the smallblock 2x4- in 340/360 port size.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: 2boltmain] #225719
02/16/09 09:01 AM
02/16/09 09:01 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is that a Hemi Shaker base? That would explain the price.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: slantzilla] #225720
02/16/09 11:39 AM
02/16/09 11:39 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Offy makes several 2X4 intakes for the small block.
Go to www.offyparts.com and get them cheaper from Summit or used.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: Rug_Trucker] #225721
02/16/09 12:16 PM
02/16/09 12:16 PM
md
mopars4ever Offline
mopars4ever  Offline
md
MR. Northdakotan (seller) is smiling all the way to the bank.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: mopars4ever] #225722
02/16/09 04:01 PM
02/16/09 04:01 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I was very dissappointed how the Offenhauser dual quad did on the Mopar magazine 383 dyno test. Very non exciting numbers- even against manifolds of the same era. Offy claimed their designs privided equal mixture thru out the rpm range. I know my setup will leave some on the table but the looks of a low rise dual quad on a V8 is intoxicating.
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: 2boltmain] #225723
02/16/09 06:00 PM
02/16/09 06:00 PM
Indiana
P
P
Indiana
Why does Edelbrock make a dual quad Air-Gap for Ford and Chevy , but not for smallblock Mopar ??
Re: Edlebrock D66 Dual Quad Intake Manifold????? [Re: Pentastar440] #225724
02/16/09 06:27 PM
02/16/09 06:27 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I acknowledge that the 350/454 chevy outsell the smallblock mopar. However, mopars are very popular and even common. I bet more of those mopars run a 360 over the 440. They brought back the 2x4 for the 440 some 19 years ago. I wish they'd do the same for the 340/360. Or at least a functionl professional products dual carb version.
