Delay box mounting #2255834
02/19/17 02:12 AM
02/19/17 02:12 AM
BigFish69 Offline OP
Could I get some pic of were you have mounted your delay box.
Thanks Tom
Re: Delay box mounting [Re: BigFish69] #2255846
02/19/17 02:36 AM
02/19/17 02:36 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Mine is off my shifter. A little too close as I usually pull the shifter down into gear to set it up...
Re: Delay box mounting [Re: Dave Hall] #2256326
02/19/17 11:50 PM
02/19/17 11:50 PM
Thanks Dave I guess we are the only two on moparts that use a delay box
Re: Delay box mounting [Re: BigFish69] #2256396
02/20/17 02:14 AM
02/20/17 02:14 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I didn't have any pictures intentionally of the delay box...
Re: Delay box mounting [Re: BigFish69] #2256651
02/20/17 04:29 PM
02/20/17 04:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine have all been like the ones pictured. Braket made off the shifter mount.
Re: Delay box mounting [Re: Al_Alguire] #2256777
02/20/17 08:12 PM
02/20/17 08:12 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Nothing fancy here but I have it mounted to the right of me and if I want to double class box and no-box its mounted on a heavy duty piece of stainless steel on Velcro. It takes about 5 seconds to remove it and plug in a 4 wire boat trailer plug and jumper so if needed my trans-brake still works.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Delay box mounting [Re: pittsburghracer] #2256878
02/20/17 11:00 PM
02/20/17 11:00 PM
Thanks for the pics looking to make quick removable type bracket
Re: Delay box mounting [Re: BigFish69] #2257267
02/21/17 05:34 PM
02/21/17 05:34 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Mine is on the roll bar right in front of me...I'll post some pics tonight wink
5.53 @ 125 1/8th on the launch control..more left in her!
