Trans brake switch/button? #2256558
02/20/17 01:33 PM
02/20/17 01:33 PM
W. Kentucky
justinp61 Online content OP
justinp61  Online Content OP
W. Kentucky
Who makes a good switch? Where do most mount it?
Re: Trans brake switch/button? [Re: justinp61] #2256583
02/20/17 02:35 PM
02/20/17 02:35 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Steering wheel and Grainger sells Omron switches. For Super class racing these are the quickest releasing I've found.
https://www.grainger.com/product/OMRON-I...archQuery=6X286
https://www.grainger.com/product/OMRON-Industrial-Snap-Action-Switch-6X288?searchQuery=6x288&suggestConfigId=6&searchBar=true&analytics=kw%3A6x288
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Trans brake switch/button? [Re: justinp61] #2256626
02/20/17 04:13 PM
02/20/17 04:13 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
This is totally up to you as there are TONS of different ones. If you are using a delay box, you can get what's the most comfortable for you. If you are bottom bulbing I highly suggest one of the adjustable units. The steering wheel is the most logical place and probably where it is mounted in most cars. The adjustable ones probably don't mount there so well. I have seen some on brackets from the dash but most adjustables are mounted to the trans. tunnel near the shifter.
Re: Trans brake switch/button? [Re: justinp61] #2256627
02/20/17 04:13 PM
02/20/17 04:13 PM
W. Kentucky
W. Kentucky
Thanks Eric. up
Re: Trans brake switch/button? [Re: justinp61] #2256697
02/20/17 05:19 PM
02/20/17 05:19 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Steering wheel. Industrial places (Grainger, MSC) have them, I always just got them from Biondo or someone like that. I also like the addition of the large red button to the switch, especially if you have to wear gloves. In a pro tree deal, the LED bulbs have made everyone a hero if the car works half decent and consistency is the main consideration. If I had a full tree, no box deal like Super Stock, etc., I would use one of the adjustable units that are available, mounted where it's comfortable and can be run consistently.
Re: Trans brake switch/button? [Re: justinp61] #2256725
02/20/17 06:07 PM
02/20/17 06:07 PM
W. Kentucky
W. Kentucky
This is a street/strip car and the brake will work in first or second gear so I'm thinking of powering the switch off a toggle switch on the dash. That way if I accidentally hit it there will be no damage.
I run some street car shoot out type stuff that's pro tree but the rest of the (little) racing I do is just brackets off a full .500 tree.
Re: Trans brake switch/button? [Re: justinp61] #2256758
02/20/17 07:25 PM
02/20/17 07:25 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I run some street car shoot out type stuff that's pro tree but the rest of the (little) racing I do is just brackets off a full .500 tree. [/quote
Is the shoot out stuff .400 protree or .500?
For bottom bulb I like http://www.biondoracing.com/product/HSA-O.html ,but everyone has there favorite. You can have a fast switch and a slow adjustable wired in parallel if you want.
I don't/won't do anything .400 because car set up needs to be fast reacting.
"Just a Bracket car dressed up like a streetcar"
Re: Trans brake switch/button? [Re: justinp61] #2256767
02/20/17 07:48 PM
02/20/17 07:48 PM
W. Kentucky
W. Kentucky
It's .500.
Re: Trans brake switch/button? [Re: justinp61] #2257271
02/21/17 05:40 PM
02/21/17 05:40 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I shimmed mine with washers also. Those switches I posted are a plunger style..but the have a very short throw to activate if you shim them.
