Re: Trans brake switch/button?
[Re: justinp61]
#2256583
02/20/17 02:35 PM
02/20/17 02:35 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Steering wheel and Grainger sells Omron switches. For Super class racing these are the quickest releasing I've found. https://www.grainger.com/product/OMRON-I...archQuery=6X286https://www.grainger.com/product/OMRON-Industrial-Snap-Action-Switch-6X288?searchQuery=6x288&suggestConfigId=6&searchBar=true&analytics=kw%3A6x288
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: justinp61]
#2256697
02/20/17 05:19 PM
02/20/17 05:19 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Steering wheel. Industrial places (Grainger, MSC) have them, I always just got them from Biondo or someone like that. I also like the addition of the large red button to the switch, especially if you have to wear gloves. In a pro tree deal, the LED bulbs have made everyone a hero if the car works half decent and consistency is the main consideration. If I had a full tree, no box deal like Super Stock, etc., I would use one of the adjustable units that are available, mounted where it's comfortable and can be run consistently.
[Re: justinp61]
#2256758
02/20/17 07:25 PM
02/20/17 07:25 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I run some street car shoot out type stuff that's pro tree but the rest of the (little) racing I do is just brackets off a full .500 tree. [/quote Is the shoot out stuff .400 protree or .500? For bottom bulb I like http://www.biondoracing.com/product/HSA-O.html ,but everyone has there favorite. You can have a fast switch and a slow adjustable wired in parallel if you want. I don't/won't do anything .400 because car set up needs to be fast reacting.
"Just a Bracket car dressed up like a streetcar"
[Re: justinp61]
#2257271
02/21/17 05:40 PM
02/21/17 05:40 PM
Eric
Pittsburgh PA
I shimmed mine with washers also. Those switches I posted are a plunger style..but the have a very short throw to activate if you shim them.
