440 with burned deck #2255551
02/18/17 05:19 PM
02/18/17 05:19 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I finally got my old 440 block on the stand to check it out. This was my original TT440 engine and I rattled the detonation so hard I broke 4 rings. I was a few hundred miles from home when I blew the head gasket between 4 and 6. Driving it that far scorched the block.
The engine was pulled, torn down, and stuffed under the bench several years ago.
I was hoping to use this block to build a cruising engine for my Imperial. What are the pros thoughts on this thing?
Deck it and run with whatever scoring is left?
Sleeve the two holes?
Scrap the block?
Other ideas?
- Stu Harmon
Re: 440 with burned deck [Re: feets] #2255580
02/18/17 06:27 PM
02/18/17 06:27 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi feets, deck it .010 and see how crooked/uneven ,cooked the deck was and then mabe deck it another .010. ronnie
Re: 440 with burned deck [Re: 1969ronnie] #2255600
02/18/17 07:19 PM
02/18/17 07:19 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have three 440 blocks in my shop right now and none of them are special to me. 1 is a complete 1977 440 MH engine and trans that I bought for $100.00, 1 is a block with main caps that was given to me and the last 1 is one out of a '77 D300 that drove onto the trailer (I paid $800.00 for the complete truck) and it has almost no ridge in the cylinders so it will be a great backup for the one 440 engine that I do care about and it is resting in the Ramcharger.
As to the scored 440...I would slide that back under your bench and find a good, low mile engine from some old man's Chrysler to refresh. Chances are you will spend less that way than doing a lot of machine work trying to make that one well again...but what do I know?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 440 with burned deck [Re: 1969ronnie] #2255605
02/18/17 07:36 PM
02/18/17 07:36 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Experimental hacking is the last thing I want to do.
If it can be repaired with sleeves then it will need to be decked afterwards. Then, I'll have a block that is decked at least .030 and I will start to run into geometry issues with the intake manifold.
I don't think going .010 will be deep enough to clear this up.
- Stu Harmon
Re: 440 with burned deck [Re: feets] #2255663
02/18/17 09:48 PM
02/18/17 09:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm not a pro, so I apologize if I'm wasting your time, but from what I can see that looks like repair would require specialized welding, decking, and at least 1 sleeve. Been in a similar situation a couple times years ago with iron heads cracked between valve seats.
Should be a decent 440 block around for less than that will cost, plus whatever other problems might be found after close inspection.
Re: 440 with burned deck [Re: feets] #2255671
02/18/17 10:12 PM
02/18/17 10:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Is it already decked? Where's the .030 figure from? My local shop can deck it and basically just 'kiss' the deck after a sleeve and only remove .005. Just enough to set the sleeve flush with the rest.
If it needs .030 to clear that crack, then disregard this post
**Photobucket sucks**
Re: 440 with burned deck [Re: feets] #2255702
02/18/17 11:16 PM
02/18/17 11:16 PM
I was hoping to use this block to build a cruising engine for my Imperial. What are the pros thoughts on this thing? Scrap the block?
Not a pro but I'd be leery of working with it. I would scrap it & find another candidate.
Re: 440 with burned deck [Re: feets] #2255713
02/18/17 11:24 PM
02/18/17 11:24 PM
Kirkland, Washington
Pacnorthcuda Offline
I'm wondering if decking the block would have a desired benefit in terms of CR (and of course making sure it's flat) for the end purpose of being the crusing mill for the Imp?
If so, pretty good reason to consider looking into it further.
Re: 440 with burned deck [Re: feets] #2255751
02/19/17 12:07 AM
02/19/17 12:07 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I would want a different block that has not been decked,because I thought you were building a good quench engine , this ditched block will probobly create a shelf piston use problem.
Re: 440 with burned deck [Re: feets] #2255793
02/19/17 01:07 AM
02/19/17 01:07 AM
I've built two motors that had worse deck damage than yours has now, one was in my pump Gas duster and the other is still in a race car today running very well up
The 440 block melted a Fel Pro Permatorque OEM replacement head gasket between #4 and # 6 cylinder blowing the deck surface and head surface out between those cylinders like a cutting torch does puke
EDITED! I had that block decked welded and then surfaced on a wet grinder, (the weld will break a rotary surfacing wheel shock) smooth enough to get a good seal and ended up using a thicker head gasket to race that motor again with 14.5+ to1 compression ratio boogie
The second motor was the block that was in my old pump gas Duster, it was blown out between the same cylinders the same way but worse runaway I had it brazed up and had two sleeves put in those two cylinders, it ended up needing two other sleeves on the other side due to pitting whiney I didn't see the deck damage when I bought that block from a friend and we didn't know about the pitting either shruggy
I beat the snot out of that motor and it ran and ruled the local streets with no problems boogie
My message is all thing mechanical are fixable, if you want to spend the money and time fixing them shruggy work
BTW, I bought and use Darton ductile iron sleeves in that block, not cheap but they sure have worked well thumbs
IHTHs
Re: 440 with burned deck [Re: feets] #2255815
02/19/17 01:42 AM
02/19/17 01:42 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I would think a diesel block repair shop that specializes in welding blocks could fix that with no problem.
Nautilus Racing-
Re: 440 with burned deck [Re: feets] #2256003
02/19/17 03:04 PM
02/19/17 03:04 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Can it be salvaged? Most likely.
Cheaper than finding another 440 block? Doubtful.
That looks more like a crack to me.
And just for reference it only took .007 to deck and square my 493.
Kevin
Re: 440 with burned deck [Re: feets] #2256333
02/19/17 11:59 PM
02/19/17 11:59 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Another thing to consider with this block, if you ran it deep enough into detonation long enough and often enough to crack it there (instead of a torch cut) there might be additional cracks or micro-fractures above the ring ridge that have not fully manifested themselves yet. And maybe not in just those two cylinders. There, just waiting until you are in the deep woods of Nova Scotia, alone, at night, miles from a decent bar...sorry...house of ill repute..sorry.. ment to say service facility and then you lose a chunk of block or cylinder wall. You then wander off from the car only to become known as the Nova Scotia Sasquatch due the size of the Imperial and the tracks leading away from the car into the woods.
I'd find another block, in simpler words, if it were me.
Re: 440 with burned deck [Re: Twostick] #2256334
02/20/17 12:04 AM
02/20/17 12:04 AM
Agreed, it sure looks like an obvious crack (& a bad/deep/extensive one to boot). I sure would be leery of investing time/money in it.
Re: 440 with burned deck [Re: feets] #2256588
02/20/17 02:42 PM
02/20/17 02:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's Bob wins this discussion !!!
Re: 440 with burned deck [Re: feets] #2257172
02/21/17 02:36 PM
02/21/17 02:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kevin , has this block been previously decked ?
Re: 440 with burned deck [Re: JohnRR] #2258332
02/23/17 09:18 PM
02/23/17 09:18 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Not to my knowledge.
I pulled this engine out of a junk yard around 1990. It looked original to the New Yorker so I don't think it had ever been opened. There have been a couple low budget builds since I've had it but those didn't include decking.
- Stu Harmon
Re: 440 with burned deck [Re: feets] #2259443
02/25/17 08:36 PM
02/25/17 08:36 PM
Minnesota
peabodyracing Offline
Minnesota
In my experience certainly fixable. Couple different ways to repair the crack that I know of. Neither is really cheap though.
Also from my experience when a B/RB block has detonated that bad the main bearing caps will walk around some. You can see this by looking carefully at the mating surfaces.
If they've bounced around the entire block has seen a fair amount of stress. Perhaps that, coupled with the deck surface crack would be enough to make you dubious of trying to save it.
Lead, follow or get the hell out of the way
Re: 440 with burned deck [Re: feets] #2259892
02/26/17 03:52 PM
02/26/17 03:52 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Can't you have the block magnafluxed/sonic checked and tell exactly how thick, and/or deep the crack is? If your local shop can't do this, then you don't want them doing the machine work anyway. Seems cheap insurance to ensure you don't sink a lot of $$$ into it,just to find it'll take a lot more money to fix it right.
In the end, only you can decide if it's worth the $$$ outlay, to fix it for what you want it for.
A True Hybrid: Burns Gas AND Rubber!
Re: 440 with burned deck [Re: feets] #2260480
02/27/17 02:12 PM
02/27/17 02:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is having the decks squared in the budget for this, that should pretty much clean that out ... assuming it's not actually a crack, which can be found via a magnaflux which would be the first thing to do to this block considering it's history.
