Hardware for chrome valve covers #2255436
02/18/17 11:58 AM
02/18/17 11:58 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Hello
Subject is a 68 383HP that came with chrome valve covers. For the mounting hardware, should this be standard bolt/nuts or are these chrome as well?
Rob
Re: Hardware for chrome valve covers [Re: njmopar] #2255450
02/18/17 12:30 PM
02/18/17 12:30 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
As in "standard" do you mean installed at the factory or installed at the dealer after the car was delivered? work
JB Rhinehart, Realist
A-Body's RULE!
Re: Hardware for chrome valve covers [Re: njmopar] #2255661
02/18/17 09:47 PM
02/18/17 09:47 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Well now I am not sure. I thought all 383 Darts had chrome. So I am guessing not based on your reply. So then they must be dealer I installed. At any rate would they use standard hardware or chrome?
Re: Hardware for chrome valve covers [Re: njmopar] #2255723
02/18/17 11:35 PM
02/18/17 11:35 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Hardware for chrome valve covers [Re: 70sixpkrt] #2255914
02/19/17 11:45 AM
02/19/17 11:45 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
So I guess just generic looking chrome bolts. Kinda cheesy looking. And I need to lose the studs in the corner hole.
Re: Hardware for chrome valve covers [Re: njmopar] #2255992
02/19/17 02:45 PM
02/19/17 02:45 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Try Mopar Performance part #P5007458. They will look good on your chrome plated valve covers. If you need to have the special cover bolt washers to spread the down force, try part #P4349620. Both of these kits are chrome plated.
Re: Hardware for chrome valve covers [Re: njmopar] #2256089
02/19/17 05:22 PM
02/19/17 05:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Keep the studs if you are wanting it to look correct. I have 67 GTX and R/T cars and I think they came with standard hardware not chrome. And the original cars have the studs in the corners and no chrome hardware, but no turquoise engine paint on them either like they were from a different car. This has been my observations over the years.
Unsure about the BB Darts, but they may have followed the same way.
Re: Hardware for chrome valve covers [Re: NANKET] #2256287
02/19/17 10:48 PM
02/19/17 10:48 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
From what I've encountered the 68 chrome valve covers didnt use chrome bolts. I also believe there was a stud on the front and rear corner. Jim, am I correct on this? shruggy
Abe Lincoln
Re: Hardware for chrome valve covers [Re: dart4forte] #2328271
06/28/17 09:27 PM
06/28/17 09:27 PM
BlueRacer69 Offline
BlueRacer69  Offline
Right you are dart4forte.
