915 Heads
#2253279
02/14/17 12:34 AM
02/14/17 12:34 AM
Posts: 16,155 Mesa, Arizona
dart4forte
Mesa, Arizona
Buddy of mine asked me to ask those in the know about 915 heads. He has a pair that has angle peanut plugs and large ports. Anybody in the know have any information I can share with him?
Abe Lincoln
Re: 915 Heads
[Re: dart4forte]
#2253315
02/14/17 01:21 AM
02/14/17 01:21 AM
RapidRobert
I have a pair of OE 915 BB iron heads. straight plugs. 2.08/1.74 std valves (iirc). I could measure the port openings if requested but yours ain't those. EDIT my exhaust valves might be 1.60" MORE EDIT Ma never made an angled SB/BB head (there is a SB 915 head).
Re: 915 Heads
[Re: RapidRobert]
#2253349
02/14/17 02:16 AM
02/14/17 02:16 AM
dart4forte
Mesa, Arizona
I have a pair of OE 915 BB iron heads. straight plugs. 2.08/1.74 std valves (iirc). I could measure the port openings if requested but yours ain't those. EDIT my exhaust valves might be 1.60" MORE EDIT Ma never made an angled SB/BB head (there is a SB 915 head). I'll ask him again on the angle plugs. These are big block heads. Huge ports, large intake and exhaust and closed chamber.
Abe Lincoln
Re: 915 Heads
[Re: dart4forte]
#2253353
02/14/17 02:29 AM
02/14/17 02:29 AM
RapidRobert
I wrote myself a note to take a pic of mine tomorrow.
Re: 915 Heads
[Re: dart4forte]
#2253427
02/14/17 10:37 AM
02/14/17 10:37 AM
Posts: 6,421 Abilene, Texas
fastmark
Abilene, Texas
Are they angled the same direction or the outter plugs angled towards each other?
Re: 915 Heads
[Re: dart4forte]
#2253469
02/14/17 12:22 PM
02/14/17 12:22 PM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
Mopar DID make angle plug big block heads. They were used on their dump truck engines. I've got a set off a 1976 D600 361 with angle plugs and they're closed chambered. Not sure of the casting numbers but I can dig them out and check.
Re: 915 Heads
[Re: GODSCOUNTRY340]
#2253507
02/14/17 01:32 PM
02/14/17 01:32 PM
RapidRobert
Oh OK so Ma DID make an angled plug (BB) head. Dart4forte we need more info/pics of what you have.
Re: 915 Heads
[Re: dart4forte]
#2253550
02/14/17 02:59 PM
02/14/17 02:59 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd say it's a fairly safe bet that the factory didnt produce any BB heads with casting number 2780915 that came with angled plugs.
Impossible? No. Just not likely.
If they indeed have angled plugs, and are that casting number, more likely they have been modified than being something made that way at the factory.
Re: 915 Heads
[Re: elmor353]
#2253707
02/14/17 09:12 PM
02/14/17 09:12 PM
RapidRobert
not good pics. BB iron OE unmodified 915's closed chambers/straight plugs.
Re: 915 Heads
#2253737
02/14/17 10:28 PM
02/14/17 10:28 PM
Posts: 219 Texas
GTS440
Texas
Mopar DID make angle plug big block heads. They were used on their dump truck engines. I've got a set off a 1976 D600 361 with angle plugs and they're closed chambered. Not sure of the casting numbers but I can dig them out and check. They were industrial heads & used a longer pushrod.
Re: 915 Heads
[Re: GTS440]
#2253772
02/14/17 11:19 PM
02/14/17 11:19 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Mopar DID make angle plug big block heads. They were used on their dump truck engines. I've got a set off a 1976 D600 361 with angle plugs and they're closed chambered. Not sure of the casting numbers but I can dig them out and check. They were industrial heads & used a longer pushrod. Different heads, intake & exhaust manifolds, water pump, cam and cam drive.
Re: 915 Heads
[Re: NANKET]
#2253891
02/15/17 02:16 AM
02/15/17 02:16 AM
RapidRobert
BB 915 heads look like a 906 from the outside, they have the same ports as a 906, and the same combustion chambers as a 516. Good info.
