915 Heads #2253279
02/14/17 12:34 AM
02/14/17 12:34 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Buddy of mine asked me to ask those in the know about 915 heads. He has a pair that has angle peanut plugs and large ports. Anybody in the know have any information I can share with him?
Abe Lincoln
Re: 915 Heads [Re: dart4forte] #2253315
02/14/17 01:21 AM
02/14/17 01:21 AM
I have a pair of OE 915 BB iron heads. straight plugs. 2.08/1.74 std valves (iirc). I could measure the port openings if requested but yours ain't those. EDIT my exhaust valves might be 1.60" MORE EDIT Ma never made an angled SB/BB head (there is a SB 915 head).
Re: 915 Heads [Re: RapidRobert] #2253349
02/14/17 02:16 AM
02/14/17 02:16 AM
Mesa, Arizona
Mesa, Arizona
I'll ask him again on the angle plugs. These are big block heads. Huge ports, large intake and exhaust and closed chamber.
Abe Lincoln
Re: 915 Heads [Re: dart4forte] #2253353
02/14/17 02:29 AM
02/14/17 02:29 AM
I wrote myself a note to take a pic of mine tomorrow.
Re: 915 Heads [Re: dart4forte] #2253354
02/14/17 02:33 AM
02/14/17 02:33 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
They only made big block 915 heads in 67. They didn't start making peanut plug heads until the mid 70's. I have a set of peanut plug big block heads and they are 452's.
Re: 915 Heads [Re: elmor353] #2253371
02/14/17 03:27 AM
02/14/17 03:27 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The 915 heads with angled plugs are SB heads for 340/360
They had 1.88 or 2.02 intakes, 1.60 exhaust
Also used on 340 six pack with 2.02 and off set drilled push rod holes
I don't know of any with a peanut plug
Re: 915 Heads [Re: dart4forte] #2253427
02/14/17 10:37 AM
02/14/17 10:37 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Are they angled the same direction or the outter plugs angled towards each other?
Re: 915 Heads [Re: dart4forte] #2253469
02/14/17 12:22 PM
02/14/17 12:22 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Mopar DID make angle plug big block heads. They were used on their dump truck engines. I've got a set off a 1976 D600 361 with angle plugs and they're closed chambered. Not sure of the casting numbers but I can dig them out and check.
Re: 915 Heads [Re: dart4forte] #2253490
02/14/17 01:04 PM
02/14/17 01:04 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I remember hearing something about Joe Jill at Speedwin Automotive in NY was slant plugging bb heads year ago.
Re: 915 Heads [Re: 446acuda] #2253497
02/14/17 01:10 PM
02/14/17 01:10 PM
Pic of chambers. Casting number 2899943.
Re: 915 Heads [Re: GODSCOUNTRY340] #2253507
02/14/17 01:32 PM
02/14/17 01:32 PM
Oh OK so Ma DID make an angled plug (BB) head. Dart4forte we need more info/pics of what you have.
Re: 915 Heads [Re: RapidRobert] #2253514
02/14/17 01:49 PM
02/14/17 01:49 PM
Mesa, Arizona
Mesa, Arizona
I'll try and get a picture
Abe Lincoln
Re: 915 Heads [Re: dart4forte] #2253550
02/14/17 02:59 PM
02/14/17 02:59 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
I'd say it's a fairly safe bet that the factory didnt produce any BB heads with casting number 2780915 that came with angled plugs.
Impossible? No.
Just not likely.
If they indeed have angled plugs, and are that casting number, more likely they have been modified than being something made that way at the factory.
Re: 915 Heads [Re: fast68plymouth] #2253695
02/14/17 08:47 PM
02/14/17 08:47 PM
E
elmor353 Offline
elmor353  Offline
E
If they are the truck heads, they sure aren't anything you'd want to use from a performance standpoint. They work fine for what they were designed for, a low rpm grunt motor.
Re: 915 Heads [Re: elmor353] #2253707
02/14/17 09:12 PM
02/14/17 09:12 PM
not good pics. BB iron OE unmodified 915's closed chambers/straight plugs.
Re: 915 Heads [Re: RapidRobert] #2253723
02/14/17 09:56 PM
02/14/17 09:56 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
At one time, someone offered a kit to convert straight plug BB heads to angle. Plug the OEM hole and drill/tap a new one.
I saw Sheldon Gecker's "King Kong" in the pits at the Gatornatonals, back when Max Wedge heads were the best thing available. He had a set of Maxies that had been converted to angle plugs.
Re: 915 Heads [Re: GODSCOUNTRY340] #2253737
02/14/17 10:28 PM
02/14/17 10:28 PM
Texas
GTS440 Offline
GTS440  Offline
Texas
They were industrial heads & used a longer pushrod.
Re: 915 Heads [Re: GTS440] #2253772
02/14/17 11:19 PM
02/14/17 11:19 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Different heads, intake & exhaust manifolds, water pump, cam and cam drive.
Re: 915 Heads [Re: dart4forte] #2253841
02/15/17 12:52 AM
02/15/17 12:52 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
BB 915 heads look like a 906 from the outside, they have the same ports as a 906, and the same combustion chambers as a 516.
Re: 915 Heads [Re: NANKET] #2253891
02/15/17 02:16 AM
02/15/17 02:16 AM
Good info.
