Best Torsion bars for drag racing? #2252748
02/13/17 01:30 AM
02/13/17 01:30 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Planning on running 11:50-11:70 with my Demon.
It's an original "H" code 340 car with the heavier rate bars.
While I have the front end apart, would it be worthwhile to lighter rate bars in?
The slant 6 ones on standard a-bodies were the lightest I believe??
Does anyone have experience doing this change? Is it worthwhile?
What gains if any is there?
Thanks all,
Wally.
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252782
02/13/17 02:53 AM
02/13/17 02:53 AM
Phoenix
jinxy Offline
jinxy  Offline
Phoenix
Bump
I'm wondering the same for my car. Mines a 408 pump gas dart that I'd like to get it to leave like a stocker.
Do the drag race bars make a big difference over v8 bars?
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252793
02/13/17 03:18 AM
02/13/17 03:18 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No IMO, using the slant 6 bars or even the lighter race bars makes the front end sloppy loose IMO. Use the standard bars you have and use adjustable front shocks. Much better option IMO. Take your front shocks completely off, and you will agree, no doubt.
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252804
02/13/17 03:57 AM
02/13/17 03:57 AM
Washington
madscientist Offline
Washington
Use the lightest spring you can to hold the car up.
Control the spring with the shocks.
Re: Best Torsion bars for drag racing? [Re: madscientist] #2252814
02/13/17 05:12 AM
02/13/17 05:12 AM
iagree
I ran the stock A body 6 cylinder torsion on my pump gas BB stroker motor Duster, 1.42 60 ft. times on M/T ET Street 325x60x15 radial tires up
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252828
02/13/17 08:58 AM
02/13/17 08:58 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I no you ask about a-body's , but I ran e-body's with the 8.50 bars with stock shocks ran 1.55-157 60'.
Re: Best Torsion bars for drag racing? [Re: Sport440] #2252838
02/13/17 10:04 AM
02/13/17 10:04 AM
Wisconsin
Wisconsin
Now why in the heck would one take shocks off of a car???
I'm not the wisest when it comes to this game, that's why I ask questions such as which torsion bar is better, but I do know a good shock absorber is a must.
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252840
02/13/17 10:10 AM
02/13/17 10:10 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I run the 6 cylinder bars and let the shocks control the rate of extension. Been 1.240
Doug
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252841
02/13/17 10:10 AM
02/13/17 10:10 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I run the 6 cylinder bars and let the shocks control the rate of extension. Stock bump stops. Been 1.240
Doug
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252854
02/13/17 11:04 AM
02/13/17 11:04 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run just a few tenths quicker. 11.30's in the heat and best of 11.19 with 1.54 60 ft. I use 6 cylinder bars with an RB and aluminum heads in an early B. I have a set of adjustables set to 90/10 and upper control arm bumper removed. The shock and bump stop removal made a world of difference!
'63 Dodge 330
11.19 @ 121 mph
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252856
02/13/17 11:08 AM
02/13/17 11:08 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
6cyl bars do not make the front end feel sloppy. you are actually cranking them up tighter to achieve the same hight so they are storing more energy. the shock controls the sloppy feeling.
JAKES AUTOMOTIVE
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252860
02/13/17 11:28 AM
02/13/17 11:28 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I could be wrong but I think the Mopar Performance torsion bars are even lighter than the six cylinder bars. I would agree with those that say to use the light bars and control with good shocks.
Bill
Re: Best Torsion bars for drag racing? [Re: JAKE68] #2252895
02/13/17 12:48 PM
02/13/17 12:48 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
work
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252913
02/13/17 01:33 PM
02/13/17 01:33 PM
AndyF Offline
AndyF  Offline
Firm Feel builds custom torsion bars for the NHRA guys so if you really want to experiment with bar rates just give them a call.
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252925
02/13/17 02:07 PM
02/13/17 02:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran the thinnest .810 iirc w/my 360 and they were good but add a BB and I went to the thicker .830 iirc w/great results...........1.33 60 foot brakin so far............. beer
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2252970
02/13/17 03:35 PM
02/13/17 03:35 PM
an8sec70cuda Offline
I still have the factory 340 torsion bars in my cuda. Been 1.310 so far on drag radials footbraking running 8.90s.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2253038
02/13/17 05:27 PM
02/13/17 05:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run the 318 bars but that's with an Aluminum headed big block.
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2253187
02/13/17 10:25 PM
02/13/17 10:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I still use the factory bars on my 63 Sport Fury. It is an original 383 car with the 383 torsion bars still in it. I put the CE 90/10 front shocks on it up front and just use the longer MP shocks in the rear that have no adjustments with 3400 lb rated SS springs. All other suspension is stock and my best 60 is a 1.50. Ron
Re: Best Torsion bars for drag racing? [Re: wkroncke17] #2253240
02/13/17 11:32 PM
02/13/17 11:32 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Having run A body stock eliminator cars for years, I ran the 6 cyl bars.83 in the beginning. When the .810 bars became available I ran those with a double adjustable shock. I am a many time NHRA record holder with 340 manual shift stockers running high 10's with a low compression 340. Use the smallest bar and a good shock. This works best if you have good rear suspension. Oh and remove or disconnect the sway bar at the track.
Real Men shift for themselves
