Re: Best Torsion bars for drag racing?
[Re: wkroncke17]
#2252804
02/13/17 03:57 AM
02/13/17 03:57 AM
Posts: 4,457 Washington
madscientist
Washington
Use the lightest spring you can to hold the car up.
Control the spring with the shocks.
[Re: Sport440]
#2252838
02/13/17 10:04 AM
02/13/17 10:04 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
No IMO, using the slant 6 bars or even the lighter race bars makes the front end sloppy loose IMO. Use the standard bars you have and use adjustable front shocks. Much better option IMO. Take your front shocks completely off, and you will agree, no doubt. Now why in the heck would one take shocks off of a car??? I'm not the wisest when it comes to this game, that's why I ask questions such as which torsion bar is better, but I do know a good shock absorber is a must.
[Re: wkroncke17]
#2252841
02/13/17 10:10 AM
02/13/17 10:10 AM
Posts: 9,866 MI, usa
dvw
MI, usa
I run the 6 cylinder bars and let the shocks control the rate of extension. Stock bump stops. Been 1.240 Doug
[Re: wkroncke17]
#2252854
02/13/17 11:04 AM
02/13/17 11:04 AM
Posts: 4,694 Wichita
GY3
Wichita
I run just a few tenths quicker. 11.30's in the heat and best of 11.19 with 1.54 60 ft. I use 6 cylinder bars with an RB and aluminum heads in an early B. I have a set of adjustables set to 90/10 and upper control arm bumper removed. The shock and bump stop removal made a world of difference!
[Re: wkroncke17]
#2252856
02/13/17 11:08 AM
02/13/17 11:08 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
6cyl bars do not make the front end feel sloppy. you are actually cranking them up tighter to achieve the same hight so they are storing more energy. the shock controls the sloppy feeling.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2252895
02/13/17 12:48 PM
02/13/17 12:48 PM
Posts: 22,697 Bitopia
jcc
Bitopia
[Re: wkroncke17]
#2252925
02/13/17 02:07 PM
02/13/17 02:07 PM
Thumperdart
State of confusion
I ran the thinnest .810 iirc w/my 360 and they were good but add a BB and I went to the thicker .830 iirc w/great results...........1.33 60 foot brakin so far.............
[Re: wkroncke17]
#2252970
02/13/17 03:35 PM
02/13/17 03:35 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I still have the factory 340 torsion bars in my cuda. Been 1.310 so far on drag radials footbraking running 8.90s.
[Re: wkroncke17]
#2253240
02/13/17 11:32 PM
02/13/17 11:32 PM
Posts: 608 TN
1DGEMAN
TN
Having run A body stock eliminator cars for years, I ran the 6 cyl bars.83 in the beginning. When the .810 bars became available I ran those with a double adjustable shock. I am a many time NHRA record holder with 340 manual shift stockers running high 10's with a low compression 340. Use the smallest bar and a good shock. This works best if you have good rear suspension. Oh and remove or disconnect the sway bar at the track.
Real Men shift for themselves
