riddle me this ... engine test stand ?? #2252355
02/12/17 04:22 PM
02/12/17 04:22 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
To be able to start a motor on a test stand you need a flywheel. On a manual trans motor you'd attach the rear at the bellhousing. With an automatic motor,do you nee to attach the whole trans ??
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2252356
02/12/17 04:28 PM
02/12/17 04:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have a spare flywheel and bellhousing for test stand purposes.
Not interested in fooling with an automatic on a test stand and I'm pretty sure you do not want to run one with out trans fluid in it either.
Don't be the exception.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2252361
02/12/17 04:31 PM
02/12/17 04:31 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
I use an empty trans case.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2252382
02/12/17 05:07 PM
02/12/17 05:07 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I built my test stand to use a transmission. My intent was to use the stand for both small and big blocks. I don't own any manual transmissions. This way I just use the proper tranny for the engine family. I just loop the cooler line.
Re: riddle me this ... engine test stand ?? [Re: forphorty] #2252534
02/12/17 08:43 PM
02/12/17 08:43 PM
okla.
sam64 Offline
sam64  Offline
okla.
empty auto case w manual flywheel here.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2252575
02/12/17 09:40 PM
02/12/17 09:40 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Planning to build a few extra and offer them for sale so I need to build it "universal" from the get go.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2252579
02/12/17 09:46 PM
02/12/17 09:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
OEM 130 tooth flywheels are fairly cheap at rockauto (think 88 Dakota V6).
A plate to bolt to the back of the engine and mount the starter should be easy to fab. I'm thinking "option accessory kit". Heck the plate could be there to mount the engine to the test stand (but it would be engine specific).
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2252753
02/13/17 01:33 AM
02/13/17 01:33 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Here's what I did, cut the bell off a 727, cut 727 convertor apart, take the guts out, cut the center out so you can access the flex plate bolts. Works like a charm.
Re: riddle me this ... engine test stand ?? [Re: GODSCOUNTRY340] #2253120
02/13/17 08:11 PM
02/13/17 08:11 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Some where on the net I found a site with Mopar acceccories , and I found a bracket for $ 14.95...that bolts to the back of the engine and the starter bolts right into that ..I made one myself , and a week later I found it on line... Don't remember the site but Just google mopar engine test stand starter bracket ..
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2253125
02/13/17 08:22 PM
02/13/17 08:22 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Ta-daa...
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2253447
02/14/17 11:32 AM
02/14/17 11:32 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
There you go ...that's the one I was talking about !!! The one I made isn't quite as neat but works just fine ..
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2253455
02/14/17 11:52 AM
02/14/17 11:52 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I drew up a plate and had it laser cut. It was my first draft of a transmission adapter plate. It cost me less than 20 bucks at the steel cutter so I keep it around as a starter adapter. I have a flywheel but an empty torque converter would work too.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2253462
02/14/17 12:07 PM
02/14/17 12:07 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Well the minor details of how guys attach their starters isn't my concern, I just want to be sure I build these things so that whatever configuration they need to mount, they can - with or without trans, with or without bellhousing.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2253976
02/15/17 12:30 PM
02/15/17 12:30 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Another one of my unfinished projects.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254051
02/15/17 03:24 PM
02/15/17 03:24 PM
I built mine with trailer hubs and a tongue so it can be moved from place to place.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254079
02/15/17 04:22 PM
02/15/17 04:22 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
pittsburghracer
Looks like we bought the same plans!
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254208
02/15/17 08:30 PM
02/15/17 08:30 PM
PA.
"Little"John
"Little"John
PA.
Originally Posted By Stanton
pittsburghracer
Well worth the price for those plans. I was going to buy one already built but there's a lot of JUNK out there. I would have been modifying it anyway. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254210
02/15/17 08:42 PM
02/15/17 08:42 PM
GA
roadrunninMark Offline
GA
Where did you find that bracket, Stanton and Dynamite?
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254227
02/15/17 09:21 PM
02/15/17 09:21 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
http://www.ebay.com/itm/383-440-MOPAR-Engine-Starter-plate-/301973329352
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254297
02/15/17 11:15 PM
02/15/17 11:15 PM
ky.
K
kenworth_goose Offline
K
ky.
So would a torque convertor work with a manual bellhousing
