Re: riddle me this ... engine test stand ??
[Re: Stanton]
#2252356
02/12/17 04:28 PM
02/12/17 04:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I have a spare flywheel and bellhousing for test stand purposes.
Not interested in fooling with an automatic on a test stand and I'm pretty sure you do not want to run one with out trans fluid in it either.
[Re: Stanton]
#2252579
02/12/17 09:46 PM
02/12/17 09:46 PM
Supercuda
About to go away
About to go away
up yours
OEM 130 tooth flywheels are fairly cheap at rockauto (think 88 Dakota V6).
A plate to bolt to the back of the engine and mount the starter should be easy to fab. I'm thinking "option accessory kit". Heck the plate could be there to mount the engine to the test stand (but it would be engine specific).
[Re: Stanton]
#2252753
02/13/17 01:33 AM
02/13/17 01:33 AM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
Here's what I did, cut the bell off a 727, cut 727 convertor apart, take the guts out, cut the center out so you can access the flex plate bolts. Works like a charm.
[Re: Stanton]
#2254051
02/15/17 03:24 PM
02/15/17 03:24 PM
GODSCOUNTRY340
I built mine with trailer hubs and a tongue so it can be moved from place to place.
[Re: Stanton]
#2254208
02/15/17 08:30 PM
02/15/17 08:30 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Looks like we bought the same plans! Well worth the price for those plans. I was going to buy one already built but there's a lot of JUNK out there. I would have been modifying it anyway. LOL
[Re: Stanton]
#2254353
02/16/17 12:25 AM
02/16/17 12:25 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
So would a torque convertor work with a manual bellhousing I'm going to go out on a limb and say that it probably would in an 11" clutch bell. My reasoning is that the 11" bell is the largest and both bell and auto trans have to fit the same tunnel in the body. Now whether or not the converter needs to be supported at the rear I can't answer.
[Re: J. Hammer]
#2254401
02/16/17 01:40 AM
02/16/17 01:40 AM
GODSCOUNTRY340
I wouldn't attempt to use a torque converter unless you also use a functional transmission attached. You can use the converter front cover and ring gear with the guts removed with a bellhousing , auto trans case,or a fabricated starter mount if you like . Correct, if you use a convertor that has the guts in it, the internals will wobble around and cause an out of balance condition. I've used a 130 tooth flywheel with my 727 bell and it works just fine so I don't see why a convertor wouldn't work with a manual bell. This 340 is running in this pic, 130 tooth flywheel with a cut off 727 bell. A 143 tooth flywheel won't fit in a 727 bell.
[Re: GODSCOUNTRY340]
#2254447
02/16/17 05:51 AM
02/16/17 05:51 AM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
I built mine with trailer hubs and a tongue so it can be moved from place to place. Pretty cool idea.
[Re: Stanton]
#2255313
02/18/17 01:31 AM
02/18/17 01:31 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I made mine after a trip to the metal recycler... I use a bellhousing and fluwheel, and the rear mount can be swapped with a wood block to run an automatic complete including running through the gears.
