Approx ET/MPH change from lighter wheels/tires? Real World? #2241320
01/25/17 11:31 PM
01/25/17 11:31 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Read all the blah blah physics about unspung weight and rotating mass.
Estimated 2950 pound ( with 250 pound me in it) car currently runs 10.84 @ 123+, dropping a total of 60 pounds, 20 from each front and 10 from each rear plus going to M/T ET fronts that are 27.5 x 4.5 from a 205/65R15 radial. Also reduced my free travel another 1.5" since the Rocky has been wheelie prone. 60' are a slow ( but controllable) 1.58 and it runs 6.90 flat in the 1/8th at just over 100.
Cant wait until spring to run it.... 'physics' calcs say about 2 tenths but im not convinced....though i Remember my Charger picked up over 2/10th going from steelies to mu first set of weld Ultralites.
WIZE
In Car:
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241345
01/26/17 12:08 AM
01/26/17 12:08 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went quicker adding weight back and no way do I see .2 in that deal.............
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241346
01/26/17 12:08 AM
01/26/17 12:08 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Google "Car Craft et improvement light wheels" and you should get a link to an older (2004) article that might be of interest.
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241372
01/26/17 12:33 AM
01/26/17 12:33 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
It might be more wheelie prone now with lighter front wheels.I've seen it on some short wheelbase Harleys,had to put the stock heavy wheel back on to keep the front down.The lighter rear wheels should help unless traction is a problem.
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: RTSrunner] #2241386
01/26/17 12:54 AM
01/26/17 12:54 AM
Weddington, N.C.
Weddington, N.C.
Thanks, I'm thinking by further limiting the free travel of the upper control arms by lowering the bump stops should counter the wheelie....it always helped before. I cam always add more ballast below the front bumper if i need to as well...obviously hoping i wont need to, lol.
The theory is that one pound of rotating weight reduction is roughly equivalent to removing 3+ pounds of static weight in terms of accelerating mass.
WIZE
In Car:
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241389
01/26/17 12:58 AM
01/26/17 12:58 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Done it, and totally hoped for the physics part of it. 1 pound of Rotational weight is Equal to 3 to 4 pounds of Dead weight.
So 60# rotational = about 180# to 240# Think the ratio was more like 1 to 3, its been awhile.
Sounds Super, doesn't it. up
Real world for me, it was Pound for Pound whether it was rotational or Dead weight.
So Why was that? I know!! Its because the car has enough time to accelerate in the 1/8-1/4 that the physics effect don't have much effect combined with the acceleration rate.
Now, hang that same 60 pounds on the Crankshaft, Different story.
So with your change maybe figure .06 as in the Old rule of Thumb. .1 for every 100# and even that is just a, well old rule of thumb and not a exact science. up
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Sport440] #2241417
01/26/17 01:37 AM
01/26/17 01:37 AM
Weddington, N.C.
Weddington, N.C.
Here is the article BradH referred to: ( Thanks!)
http://www.hotrod.com/articles/light-vs-heavy-wheels-comparison/
With the fronts jacked up off the ground you can visualize taking something like an electric motor attached to the hub and accelerating each wheel to simulate top end speed rpm in roughly10.8 seconds taking a lot less energy amps/Kw//Hp than the massively heavy 4x4 wheels that were on it. I guess the et fronts are also about 2" taller so they'll spin a little slower too over the course of a run. 60 pounds is a little more than 2% reduction so roughly like 80 on a 4000 car.
My guess is around .15 seconds so probably worth it. Had to drastically cut down the hub register and redrill the bolt pattern to get the fronts to fit.
Time will tell tho...i tell you at least its easier to push around the garage, lol
WIZE
In Car:
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241449
01/26/17 02:41 AM
01/26/17 02:41 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
While I do believe the advantages and would want more weight off the rotational weight vs static weight, even Brads article kind of confirms, that at the rate of witch a car accelerates in the 1/4. that it isn't even Close to the 1# to 3# difference advantage that is and was Advertised of the Physics back in the day or even today. To be accurate, It would have to be Time specific of time traveled with rotational weight differences vs static. Actually more to it then that.
As far as the article, it even shows a lessor gain from the rule of thumb .1 ET for each 100# loss from #3 test, but more, then on test #4
Test 3 shows With a 53.74# weight loss of Rotational, a .034 Gain.
Test 4 shows With a 82.08# weight loss of rotational, a .110 Gain.
Even this testing has accuracy issues. But, All can and Should conclude. No where close to the 1# to 3# advantage of rotational vs static. That I hoped for and most others, not down the 1/4 anyways.
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Sport440] #2241507
01/26/17 10:14 AM
01/26/17 10:14 AM
Weddington, N.C.
Weddington, N.C.
I agree, I'm with you.....just don't know if with a much lighter car and a higher power to weight ratio it might make more of a difference than it would in a 2 ton big block chevelle.
Biggest handicap in my combo is not the wheelbase, its the lack of Aerodynamics! Lol
WIZE
In Car:
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241512
01/26/17 10:29 AM
01/26/17 10:29 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
where's Monty??
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241537
01/26/17 11:49 AM
01/26/17 11:49 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Specifically?
The tests I've read have no input for the MOI: where is the inertial center of mass of the wheel located? The OD gives nothing useful.
Read my article: http://victorylibrary.com/mopar/sprung.htm
Boffin Emeritus
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241651
01/26/17 02:29 PM
01/26/17 02:29 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
As Poly says. In my layman's terms: If a component is a given diameter the part that has nearly all of its weight at the outer circumference (such as a tire) will have more effect than a part with the weight concentrated near its centerline (such as an axle shaft). Exactly the same as a chassis. If the weight is close to the CG it will rotate with less input than one with all the weight at the ends. How much better? Testing will tell.
Doug
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2241674
01/26/17 03:13 PM
01/26/17 03:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Ever use a spin balancer and see how easy a 13" Honda wheel starts and stops compared to a 3/4 ton picking 16" tire?
It will change ET and MPH, but the change is different on a 10 vs15 second car, also the torque of the engine, SB vs BB.
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: jughed] #2241691
01/26/17 03:30 PM
01/26/17 03:30 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted By jughed
where's Monty??
I believe Monte is helping Chad Henderson get the Buick ready for testing. Just saw the car is repainted, and new bullet in.
69 GTX 68 Road Runner
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: JERICOGTX] #2241816
01/26/17 07:22 PM
01/26/17 07:22 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: cruzin] #2250778
02/10/17 12:51 AM
02/10/17 12:51 AM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
My 69 GTX with a 493 has gone as fast as 10.84 at 123.50 with a 1.49 60 ft. 3960lbs with driver, 3.73 gear. This combo makes 494 RWHP.
I made 3 passes with my magnum 500s that had Hoosier drag radials, then switched to my centerlines with the same exact tires. I weighed the wheels and tires at the track as I swapped them. The centerlines were 38 lbs lighter.
After 3 more passes with the Center lines the improvement was.....ZERO!!!!! No change in 60 ft 1/4 mile ET or MPH.
Would it make a difference on a 3000 lbs car? maybe ...
Also tried an electric water pump and fan set up vs 5 blade clutch fan with no improvement in ET or MPH
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: mercman1] #2250890
02/10/17 04:58 AM
02/10/17 04:58 AM
How's your fuel supply? scope
Many things can hold us back with out us knowing it, I guarantee it shruggy
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Streetwize] #2250970
02/10/17 12:32 PM
02/10/17 12:32 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the wheel weight difference were almost entirely located in the hub, the advantage would be limited to less than 1% change in the overall weight.
Boffin Emeritus
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: Cab_Burge] #2251456
02/11/17 03:38 AM
02/11/17 03:38 AM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Cab, owned this car for over 20 years and this combo for over 16 years. 6.5 psi on dyno pull after dyno pull. Mallory comp 180 pump with 3/8 lines. Fuel/air is a tad rich at 12.5. It is not lacking fuel.
I think this car is maxed out on MY definition of a street car. Pump gas, power steering, power brakes, nice stereo, full auto valve body, 3.73 gears. I know that this combo is not to far away of failing a block. Just a bad tune up or a broken valve spring away.
Oh by the way this is a rotisserie restored car that has won 1st place 3 years in a row at Mopars with Big Daddy and in 1999 or 2000 at the Hot Rod magazine Power tour, in a sea of red Camaros, won "Best Street Machine, Non Tubbed"
I am always chasing the next tenth, but as stated, the lighter wheel combo and the electric water pump/fan and even removing the power steering belt did nothing to improve ET or MPH on this car.
Re: Approx ET/MPH change from lighter wheels/tires? Real World? [Re: mercman1] #2251462
02/11/17 04:47 AM
02/11/17 04:47 AM
Sometimes cars don't react like we think they should, just like women shock haha whistling
