Re: Approx ET/MPH change from lighter wheels/tires? Real World?
[Re: Streetwize]
#2241345
01/26/17 12:08 AM
01/26/17 12:08 AM
Thumperdart
State of confusion
I went quicker adding weight back and no way do I see .2 in that deal.............
[Re: Streetwize]
#2241389
01/26/17 12:58 AM
01/26/17 12:58 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Done it, and totally hoped for the physics part of it. 1 pound of Rotational weight is Equal to 3 to 4 pounds of Dead weight. So 60# rotational = about 180# to 240# Think the ratio was more like 1 to 3, its been awhile. Sounds Super, doesn't it. Real world for me, it was Pound for Pound whether it was rotational or Dead weight. So Why was that? I know!! Its because the car has enough time to accelerate in the 1/8-1/4 that the physics effect don't have much effect combined with the acceleration rate. Now, hang that same 60 pounds on the Crankshaft, Different story. So with your change maybe figure .06 as in the Old rule of Thumb. .1 for every 100# and even that is just a, well old rule of thumb and not a exact science.
[Re: Sport440]
#2241417
01/26/17 01:37 AM
01/26/17 01:37 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Here is the article BradH referred to: ( Thanks!) http://www.hotrod.com/articles/light-vs-heavy-wheels-comparison/With the fronts jacked up off the ground you can visualize taking something like an electric motor attached to the hub and accelerating each wheel to simulate top end speed rpm in roughly10.8 seconds taking a lot less energy amps/Kw//Hp than the massively heavy 4x4 wheels that were on it. I guess the et fronts are also about 2" taller so they'll spin a little slower too over the course of a run. 60 pounds is a little more than 2% reduction so roughly like 80 on a 4000 car. My guess is around .15 seconds so probably worth it. Had to drastically cut down the hub register and redrill the bolt pattern to get the fronts to fit. Time will tell tho...i tell you at least its easier to push around the garage, lol
[Re: Streetwize]
#2241449
01/26/17 02:41 AM
01/26/17 02:41 AM
Sport440
Canton, Ohio
While I do believe the advantages and would want more weight off the rotational weight vs static weight, even Brads article kind of confirms, that at the rate of witch a car accelerates in the 1/4. that it isn't even Close to the 1# to 3# difference advantage that is and was Advertised of the Physics back in the day or even today. To be accurate, It would have to be Time specific of time traveled with rotational weight differences vs static. Actually more to it then that.
As far as the article, it even shows a lessor gain from the rule of thumb .1 ET for each 100# loss from #3 test, but more, then on test #4
Test 3 shows With a 53.74# weight loss of Rotational, a .034 Gain.
Test 4 shows With a 82.08# weight loss of rotational, a .110 Gain.
Even this testing has accuracy issues. But, All can and Should conclude. No where close to the 1# to 3# advantage of rotational vs static. That I hoped for and most others, not down the 1/4 anyways.
[Re: Streetwize]
#2241537
01/26/17 11:49 AM
01/26/17 11:49 AM
Posts: 4,209 New York
polyspheric
New York
Read all the blah blah physics about unspung weight and rotating mass Specifically? The tests I've read have no input for the MOI: where is the inertial center of mass of the wheel located? The OD gives nothing useful. Read my article: http://victorylibrary.com/mopar/sprung.htm
Boffin Emeritus
[Re: jughed]
#2241691
01/26/17 03:30 PM
01/26/17 03:30 PM
Posts: 10,038 MN
JERICOGTX
MN
I believe Monte is helping Chad Henderson get the Buick ready for testing. Just saw the car is repainted, and new bullet in.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2241816
01/26/17 07:22 PM
01/26/17 07:22 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
[Re: Streetwize]
#2250970
02/10/17 12:32 PM
02/10/17 12:32 PM
polyspheric
New York
If the wheel weight difference were almost entirely located in the hub, the advantage would be limited to less than 1% change in the overall weight.
Boffin Emeritus
[Re: Cab_Burge]
#2251456
02/11/17 03:38 AM
02/11/17 03:38 AM
Posts: 546 Stuart FL
mercman1
Stuart FL
Cab, owned this car for over 20 years and this combo for over 16 years. 6.5 psi on dyno pull after dyno pull. Mallory comp 180 pump with 3/8 lines. Fuel/air is a tad rich at 12.5. It is not lacking fuel. I think this car is maxed out on MY definition of a street car. Pump gas, power steering, power brakes, nice stereo, full auto valve body, 3.73 gears. I know that this combo is not to far away of failing a block. Just a bad tune up or a broken valve spring away. Oh by the way this is a rotisserie restored car that has won 1st place 3 years in a row at Mopars with Big Daddy and in 1999 or 2000 at the Hot Rod magazine Power tour, in a sea of red Camaros, won "Best Street Machine, Non Tubbed" I am always chasing the next tenth, but as stated, the lighter wheel combo and the electric water pump/fan and even removing the power steering belt did nothing to improve ET or MPH on this car.
[Re: mercman1]
#2251462
02/11/17 04:47 AM
02/11/17 04:47 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
