Power Brake Booster '70 B Body #2250019
02/08/17 11:40 PM
02/08/17 11:40 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Lost the brakes in my GTX. I have very low vacuum due to the cam so the brakes are usually sketchy at best but now I have nothing (extremely hard pedal). I believe it can only be the master cylinder or the power booster. All the vacuum lines are OK and I do have an aftermarket reservoir under the battery tray to increase vacuum reserves. Getting ready to dive in so I decided to look for a new power booster in case I need one but I can't find one anywhere for a '70 B body. What options are out there??? I prefer stock-ish look for the GTX but may stray from that if I can find something that will give me good brakes with 6" Hg at idle.
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250029
02/08/17 11:52 PM
02/08/17 11:52 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
With only 6" at idle you may want to consider a Hydro-Boost setup. Of course, that won't look anywhere near stock. Those dual diaphram Bendix boosters are hard to find. Near impossible. Consider sending yours out for a rebuild if you have an original.
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250034
02/08/17 11:58 PM
02/08/17 11:58 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Yeah, I don't want to go with the hydro-boost, but it's a good idea.
If I end up not being able to find an original replacement I'll have to see if I can find a place that will rebuild mine.
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250112
02/09/17 01:26 AM
02/09/17 01:26 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Are the originals really a dual diaphragm unit?
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250113
02/09/17 01:27 AM
02/09/17 01:27 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Also, what is the chance that after sitting for 4-5 months the master cylinder is causing the very hard pedal and not the booster?
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250123
02/09/17 01:42 AM
02/09/17 01:42 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
BOOSTER DEWEY
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250132
02/09/17 01:50 AM
02/09/17 01:50 AM
Andrewh Offline
Andrewh  Offline
while they do fail, I would start looking at your vacuum reserve first.
see if you have a leak somewhere else.
put a vacuum pump on the booster and see if it holds vacuum and the brakes get better.
a bad master doesn't fail like that normally.
pedal to the floor for a bad master, or slowly falling when holding the brakes.
hard pedal is lack of vacuum or bad booster.
they also make the electric vacuum pumps to help too. you could hide that and thus still look stock.
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250144
02/09/17 02:13 AM
02/09/17 02:13 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I've looked at the lines and reserve tanks and they seemed fine (had my 6" of vacuum at the fitting to the booster.
I'll have to find a consistent vacuum source to check the booster. I have one of the hand units and I tried to pump up the booster but after 5 minutes I was only up to ~10" of vacuum. Not enough volume in that little pump.
I've seen the electric pumps, they're pretty expensive but I guess fixing the front of the car due to an accident would cost more!!
Re: Power Brake Booster '70 B Body [Re: hemi71x] #2250145
02/09/17 02:14 AM
02/09/17 02:14 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
BOOSTER DEWEY
I had no idea what you were talking about so I searched the net. Not too bad of price and not too far away. Thanks for the information!!!!
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250155
02/09/17 02:36 AM
02/09/17 02:36 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Is it a disc brake or drum brake car? The boosters are different. Do you have a car with 15+ inches of vacuum? Even a new car. Run a long hose from that car to the booster on the GTX and see what it does.
But I will say that your booster is,bad, and the master is not causing this problem.
You might try removing the booster and run in them as manual brakes.
Booster Dewey is the place to go for booster rebuild.
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250603
02/09/17 08:31 PM
02/09/17 08:31 PM
Chicago
PurpleBeeper Offline
Chicago
I've got a couple more thoughts for you since about 6 months ago my '70 Road Runner lost its brakes (hard pedal, not going to the floor, but no brakes).
1. My car's problem was TWO bad Inline Tube metering valve/proportioning valve (split on '70, can't remember the correct name, but the part where you hold the little pin out to bleed the brakes). The quality control on those parts is TERRIBLE.
2. You can get a pretty close to original looking brake booster (dual diaphragm) which they sell on Ebay. I had to slightly (1/8") enlarge the hole in my firewall (not visible once installed) and I did not need to buy the "heavy duty bracket", maybe because my car was stock front disc.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2250611
02/09/17 08:42 PM
02/09/17 08:42 PM
cmansell Offline
cmansell  Offline
the airgrabber hood is a good place to lose vacuum and the switch under the dash will also leak.
Re: Power Brake Booster '70 B Body [Re: NANKET] #2250726
02/09/17 11:40 PM
02/09/17 11:40 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
It is a disc brake car. When the weather improves enough (foot of snow on the ground now) I'll put another car along side and see what happens then. Thanks for the suggestion.
Re: Power Brake Booster '70 B Body [Re: PurpleBeeper] #2250727
02/09/17 11:42 PM
02/09/17 11:42 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Wow, never heard of the metering valves doing that. Must have been preventing the fluid from reaching the caliper/wheel cylinders so it had a hard pedal.
Re: Power Brake Booster '70 B Body [Re: cmansell] #2250728
02/09/17 11:43 PM
02/09/17 11:43 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Good call. I think I checked everything for leaks but I will double check before I spend any money on parts.
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2256462
02/20/17 04:56 AM
02/20/17 04:56 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Booster Dewey if you need a rebuild...
Re: Power Brake Booster '70 B Body [Re: VITC_GTX] #2256536
02/20/17 01:06 PM
02/20/17 01:06 PM
Chicago
Chicago
Yep, that's exactly what the mechanic told me. After replacing it twice from two different vendors I was ignoring what was obvious.
