Power Brake Booster '70 B Body
#2250019
02/08/17 11:40 PM
02/08/17 11:40 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
Lost the brakes in my GTX. I have very low vacuum due to the cam so the brakes are usually sketchy at best but now I have nothing (extremely hard pedal). I believe it can only be the master cylinder or the power booster. All the vacuum lines are OK and I do have an aftermarket reservoir under the battery tray to increase vacuum reserves. Getting ready to dive in so I decided to look for a new power booster in case I need one but I can't find one anywhere for a '70 B body. What options are out there??? I prefer stock-ish look for the GTX but may stray from that if I can find something that will give me good brakes with 6" Hg at idle.
Re: Power Brake Booster '70 B Body
[Re: VITC_GTX]
#2250123
02/09/17 01:42 AM
02/09/17 01:42 AM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Yeah, I don't want to go with the hydro-boost, but it's a good idea.
If I end up not being able to find an original replacement I'll have to see if I can find a place that will rebuild mine. BOOSTER DEWEY
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#2250145
02/09/17 02:14 AM
02/09/17 02:14 AM
VITC_GTX
If I end up not being able to find an original replacement I'll have to see if I can find a place that will rebuild mine. BOOSTER DEWEY I had no idea what you were talking about so I searched the net. Not too bad of price and not too far away. Thanks for the information!!!!
[Re: VITC_GTX]
#2250603
02/09/17 08:31 PM
02/09/17 08:31 PM
Posts: 958 Chicago
PurpleBeeper
Chicago
I've got a couple more thoughts for you since about 6 months ago my '70 Road Runner lost its brakes (hard pedal, not going to the floor, but no brakes).
1. My car's problem was TWO bad Inline Tube metering valve/proportioning valve (split on '70, can't remember the correct name, but the part where you hold the little pin out to bleed the brakes). The quality control on those parts is TERRIBLE.
2. You can get a pretty close to original looking brake booster (dual diaphragm) which they sell on Ebay. I had to slightly (1/8") enlarge the hole in my firewall (not visible once installed) and I did not need to buy the "heavy duty bracket", maybe because my car was stock front disc.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: NANKET]
#2250726
02/09/17 11:40 PM
02/09/17 11:40 PM
VITC_GTX
Is it a disc brake or drum brake car? The boosters are different. Do you have a car with 15+ inches of vacuum? Even a new car. Run a long hose from that car to the booster on the GTX and see what it does.
But I will say that your booster is,bad, and the master is not causing this problem.
You might try removing the booster and run in them as manual brakes.
Booster Dewey is the place to go for booster rebuild. It is a disc brake car. When the weather improves enough (foot of snow on the ground now) I'll put another car along side and see what happens then. Thanks for the suggestion.
[Re: PurpleBeeper]
#2250727
02/09/17 11:42 PM
02/09/17 11:42 PM
VITC_GTX
2. You can get a pretty close to original looking brake booster (dual diaphragm) which they sell on Ebay. I had to slightly (1/8") enlarge the hole in my firewall (not visible once installed) and I did not need to buy the "heavy duty bracket", maybe because my car was stock front disc. Wow, never heard of the metering valves doing that. Must have been preventing the fluid from reaching the caliper/wheel cylinders so it had a hard pedal.
[Re: cmansell]
#2250728
02/09/17 11:43 PM
02/09/17 11:43 PM
VITC_GTX
the airgrabber hood is a good place to lose vacuum and the switch under the dash will also leak. Good call. I think I checked everything for leaks but I will double check before I spend any money on parts.
[Re: VITC_GTX]
#2256536
02/20/17 01:06 PM
02/20/17 01:06 PM
Posts: 958 Chicago
PurpleBeeper
Chicago
2. You can get a pretty close to original looking brake booster (dual diaphragm) which they sell on Ebay. I had to slightly (1/8") enlarge the hole in my firewall (not visible once installed) and I did not need to buy the "heavy duty bracket", maybe because my car was stock front disc. Wow, never heard of the metering valves doing that. Must have been preventing the fluid from reaching the caliper/wheel cylinders so it had a hard pedal. Yep, that's exactly what the mechanic told me. After replacing it twice from two different vendors I was ignoring what was obvious.
