How do I remove surface rust without blasting?? #225009
02/14/09 08:24 PM
02/14/09 08:24 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I'm ready to restore my brake pedal assembly and have surface rust all over...as everything was bare metal.
I could bead blast, but it would not have the original sheen at that point.
I was thinking of a muratic acid and water solution to dip them in. Would this be too harsh to try?
Any suggestions?
Re: How do I remove surface rust without blasting?? [Re: cdp] #225010
02/14/09 08:30 PM
02/14/09 08:30 PM
GMP440 Offline
GMP440  Offline
Fill a container with Ospho and let it sit for about an hour or so. Rust will be gone and you will have clean metal again.
Re: How do I remove surface rust without blasting?? [Re: GMP440] #225011
02/14/09 08:36 PM
02/14/09 08:36 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Where do I get Ospho? Heard of it, but never used it.
Re: How do I remove surface rust without blasting?? [Re: cdp] #225012
02/14/09 08:52 PM
02/14/09 08:52 PM
GMP440 Offline
GMP440  Offline
Advance Auto and Pep Boys sell it. Also any auto paint supply store will have it too.
Re: How do I remove surface rust without blasting?? [Re: GMP440] #225013
02/14/09 09:13 PM
02/14/09 09:13 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I never treid the ospho but have used PPGDX579 thnk it is close to the same thing
Re: How do I remove surface rust without blasting?? [Re: 340SIX] #225014
02/14/09 09:19 PM
02/14/09 09:19 PM
MO
cdp Offline OP
cdp  Offline OP
MO
PPG.....10x more expensive I bet.
Re: How do I remove surface rust without blasting?? [Re: cdp] #225015
02/14/09 09:36 PM
02/14/09 09:36 PM
SK, Canada
E
etek Offline
etek  Offline
E
SK, Canada
OPSHO is just diluted Phosporic Acid. You can either get it straight, or in Brands like Metal Ready (from POR15).
But it leaves a white residue (or black if really heavy), so your "sheen" will be gone. Of course once you have surface rust the sheen is gone anyways, so whatever, right?! I'd sand or bead blast if your have access, then paint it with a Cast Silver, or spray Graphite Lube on it and rub it - it leaves a clean dark metal look (just the lead is left once the carriers flash off- Awesome on manifolds).
Re: How do I remove surface rust without blasting?? [Re: etek] #225016
02/14/09 09:45 PM
02/14/09 09:45 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
The safest way to remove surface rust without blasting AND not use ANY corrosive chemicals is Ultra One.
I use it and it works.
Miss Belvedere is at the Ultra One shop.
http://www.ultraone.com/
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: How do I remove surface rust without blasting?? [Re: cdp] #225017
02/15/09 10:51 AM
02/15/09 10:51 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
The last thing you want to do is sandblast those bare steel underdash parts. You will ruin the natural look to it. Here is a picture of an assembly that I did a while back. I submerge them in Evaporust. They come out looking like new with all the shiney stamping lines still visible. I do them same with all other bare steel underdash parts like the E-brake and the heater box.
Re: How do I remove surface rust without blasting?? [Re: hemi70se] #225018
02/15/09 10:58 AM
02/15/09 10:58 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Thanks, thats the finish I'm wanting. I do have a few quarts of metal ready that I put misc. half rusty bolts and nuts in and let them set a while. But I havn't had much luck with pitted metal and such and thought it would be too harsh for what I wanted.
I did order som Ultraone. I see some other things like E-brake cables and stuff I could use it for as well as the degreaser.
Re: How do I remove surface rust without blasting?? [Re: cdp] #225019
02/15/09 12:05 PM
02/15/09 12:05 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Hot Rod just did an article on this
http://www.hotrod.com/techarticles/body/hrdp_0901_rust_removal_guide/index.html
Good luck, and keep those parts looking factory!
Re: How do I remove surface rust without blasting?? [Re: RodStRace] #225020
02/15/09 05:03 PM
02/15/09 05:03 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Evaporust works great...AND is very safe.
Re: How do I remove surface rust without blasting?? [Re: THESHAKERPROJECT] #225021
02/15/09 05:12 PM
02/15/09 05:12 PM
MO
cdp Offline OP
cdp  Offline OP
MO
i went to Harbor Freight today to get some moving blankets and they had evopo-rust. I bought a gallon and am going to give it a test try. I'll post some pics.
Re: How do I remove surface rust without blasting?? [Re: cdp] #225022
02/17/09 09:54 PM
02/17/09 09:54 PM
MO
cdp Offline OP
cdp  Offline OP
MO
A few parts soaked overnight in Evapo-rust, then used a plastic bristle brush to scrub down with. This is what I got. A before and after.
Re: How do I remove surface rust without blasting?? [Re: cdp] #225023
02/17/09 09:56 PM
02/17/09 09:56 PM
MO
cdp Offline OP
cdp  Offline OP
MO
after
Re: How do I remove surface rust without blasting?? [Re: hemi70se] #225024
02/18/09 12:36 AM
02/18/09 12:36 AM
340SIX Offline
340SIX  Offline
How do you keep them looking like that? A flat clear?
Re: How do I remove surface rust without blasting?? [Re: 340SIX] #225025
02/18/09 01:23 AM
02/18/09 01:23 AM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Yes, I strongly agree, Evapo-Rust is the way to go.
I have been using and raving about this product for 4 or 5 years. I use to have to order it from the manufacturer in Arkansas before it went to the mass merchants. Its great stuff. Just be sure to clear the parts to protect them when you are done cleaning them or the will start to rust.
Re: How do I remove surface rust without blasting?? [Re: 340SIX] #225026
02/18/09 01:26 AM
02/18/09 01:26 AM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
I like to use a satin clear myself.
Re: How do I remove surface rust without blasting?? [Re: BADBEE] #225027
02/18/09 07:26 AM
02/18/09 07:26 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I was planning on a satin clear also. Something like I used on my heater box. Krylon Satin clear.
Re: How do I remove surface rust without blasting?? [Re: cdp] #225028
02/18/09 01:07 PM
02/18/09 01:07 PM
340SIX Offline
340SIX  Offline
Don't think it would work good on a large part like a floor secton since it will have to stay wet to work.
I wonder what percentage the evapo rust is compaired to the PPG DX579
I have some of that and it must stay wet to work. It smells nasty and ya gotta wear gloves.
