Re: Lash caps stuck
[Re: emarine01]
#224980
02/14/09 09:06 PM
02/14/09 09:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I assume you had the vise grips on the lash cap, put them on the valve stem(not tight) and use a hammer hitting up on the vise grips EDIT Or you could get fancy and make a slid hammer set up with a U shape.... of course this is if you can compress the spring enough
Re: Lash caps stuck
[Re: S/ST 3040]
#224981
02/14/09 09:10 PM
02/14/09 09:10 PM
Posts: 3,695 nc
emarine01
nc
Yes, the keepers.
Got ya, I allways find it kinda hairy doing this with heads on but weve been there before , thanks
Re: Lash caps stuck
[Re: emarine01]
#224985
02/14/09 09:33 PM
02/14/09 09:33 PM
MR_P_BODY
One more quik question , how are you guys locking up the engine wile filling the cylinder with air , my engine wants to roll sometimes if you arent perfect on tdc.
I let it go to the bottom with the air
Re: Lash caps stuck
[Re: MR_P_BODY]
#224987
02/14/09 09:50 PM
02/14/09 09:50 PM
Posts: 3,695 nc
emarine01
nc
I did that once 20 years ago ,droped a intake in a cyl on a V12 650kw genset, and thats the kinda karma Ive had with these valve seals so far , I should just pull the head and cut it to the chase,
Re: Lash caps stuck
[Re: emarine01]
#224988
02/14/09 09:56 PM
02/14/09 09:56 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Dont have lots of room between crank and rad , Ive been puting a wedge in the power steering belt @ the pully , it has worked in the past but I dont think its fool proof & the way this has been going so far, I havent caught a break on simple things messing up
i had to put w wood wedge in the starter gear to trans case to tighten the crank bolt.
Re: Lash caps stuck
[Re: S/ST 3040]
#224991
02/14/09 10:21 PM
02/14/09 10:21 PM
MR_P_BODY
I hit the keeper with a mallet to break the keepers and locks free then it the air to it then proceed to take it apart... never had a valve drop in
Re: Lash caps stuck
[Re: Bigbeep]
#224994
02/15/09 02:07 AM
02/15/09 02:07 AM
Posts: 602 Alexandria, VA
SealockRacing
Alexandria, VA
A buddy showed me this. With rockers and spark plugs pulled. Get a small diameter rope a few feet long. Tie a knot in one end. Insert other end into the plug hole and keep feeding rope into hole. Rotate piston as far up into the cylinder as possible. Pop spring off and rope will keep valve up in head. This works good at the track if you have no air. Beep
used to do this with my little goped scooters, kept the piston from moving so i could take the flywheel nuts off!
