Lash caps stuck #224975
02/14/09 07:47 PM
02/14/09 07:47 PM
nc
E
emarine01 Offline OP
E
nc
Hey all, got 3 lash caps that dont want to come off, the others pulled off with my fingers , cant pull last 3 even with vise gripps, I have the keepers with the groove in them for the caps so cant get under them to pry, anybody got any good ideas? head is W5 with single groove 10 degree locks & still on engine , thanks
Re: Lash caps stuck [Re: emarine01] #224976
02/14/09 08:29 PM
02/14/09 08:29 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
what about heating them up?
Re: Lash caps stuck [Re: emarine01] #224977
02/14/09 08:32 PM
02/14/09 08:32 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
You'll have to take the springs off.
Re: Lash caps stuck [Re: S/ST 3040] #224978
02/14/09 08:42 PM
02/14/09 08:42 PM
nc
E
E
nc
I think the caps are hardend so dont know if heat will mess them up, I need to get the caps off to get to the springs? or did you mean compress the springs and try to split the keepers from the sides?
Re: Lash caps stuck [Re: emarine01] #224979
02/14/09 08:54 PM
02/14/09 08:54 PM
S/ST 3040 Offline
S/ST 3040  Offline
Yes, the keepers.
Re: Lash caps stuck [Re: emarine01] #224980
02/14/09 09:06 PM
02/14/09 09:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you had the vise grips on the lash cap, put
them on the valve stem(not tight) and use a hammer
hitting up on the vise grips
EDIT
Or you could get fancy and make a slid hammer set up
with a U shape.... of course this is if you can compress
the spring enough
Re: Lash caps stuck [Re: S/ST 3040] #224981
02/14/09 09:10 PM
02/14/09 09:10 PM
nc
E
E
nc
Yes, the keepers.
Got ya, I allways find it kinda hairy doing this with heads on but weve been there before , thanks
Re: Lash caps stuck [Re: emarine01] #224982
02/14/09 09:19 PM
02/14/09 09:19 PM
ELYRIA,OH
ELYRIA,OH
maybe this is a last resort but use a whiz wheel grinding so the dabris goes to the outside to the exhaust and placing wrags around area to help keep it all clean.
grind the cap down to the stem almost and it should give.
Re: Lash caps stuck [Re: emarine01] #224983
02/14/09 09:20 PM
02/14/09 09:20 PM
nc
E
E
nc
One more quik question , how are you guys locking up the engine wile filling the cylinder with air , my engine wants to roll sometimes if you arent perfect on tdc.
Re: Lash caps stuck [Re: emarine01] #224984
02/14/09 09:31 PM
02/14/09 09:31 PM
ELYRIA,OH
ELYRIA,OH
if you dont mind me saying put a extension on the wratchet and bring it to rest on the frame[driver side.]or a braker bar.
Re: Lash caps stuck [Re: emarine01] #224985
02/14/09 09:33 PM
02/14/09 09:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I let it go to the bottom with the air
Re: Lash caps stuck [Re: blownzoom440] #224986
02/14/09 09:44 PM
02/14/09 09:44 PM
nc
E
E
nc
Dont have lots of room between crank and rad , Ive been puting a wedge in the power steering belt @ the pully , it has worked in the past but I dont think its fool proof & the way this has been going so far, I havent caught a break on simple things messing up
Re: Lash caps stuck [Re: MR_P_BODY] #224987
02/14/09 09:50 PM
02/14/09 09:50 PM
nc
E
E
nc
I did that once 20 years ago ,droped a intake in a cyl on a V12 650kw genset, and thats the kinda karma Ive had with these valve seals so far , I should just pull the head and cut it to the chase,
Re: Lash caps stuck [Re: emarine01] #224988
02/14/09 09:56 PM
02/14/09 09:56 PM
ELYRIA,OH
ELYRIA,OH
i had to put w wood wedge in the starter gear to trans case to tighten the crank bolt.
Re: Lash caps stuck [Re: blownzoom440] #224989
02/14/09 10:07 PM
02/14/09 10:07 PM
nc
E
E
nc
That sounds doable , I might have to bribe one of my kids to help
Re: Lash caps stuck [Re: emarine01] #224990
02/14/09 10:09 PM
02/14/09 10:09 PM
S/ST 3040 Offline
S/ST 3040  Offline
Maybe it's just me but, I never use air.
Piston @ TDC and bump the top of the piston to jar the keepers loose.
Valve seal keeps the valve seated to remove the springs.
Re: Lash caps stuck [Re: S/ST 3040] #224991
02/14/09 10:21 PM
02/14/09 10:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I hit the keeper with a mallet to break the keepers
and locks free then it the air to it then proceed to
take it apart... never had a valve drop in
Re: Lash caps stuck [Re: S/ST 3040] #224992
02/14/09 10:25 PM
02/14/09 10:25 PM
nc
E
E
nc
Hey good thought, Thats something Ive not tryed ,Might compress the spring a lot but cant lose a valve
Re: Lash caps stuck [Re: emarine01] #224993
02/15/09 01:33 AM
02/15/09 01:33 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
A buddy showed me this. With rockers and spark plugs pulled. Get a small diameter rope a few feet long. Tie a knot in one end. Insert other end into the plug hole and keep feeding rope into hole. Rotate piston as far up into the cylinder as possible. Pop spring off and rope will keep valve up in head. This works good at the track if you have no air. Beep
Re: Lash caps stuck [Re: Bigbeep] #224994
02/15/09 02:07 AM
02/15/09 02:07 AM
Alexandria, VA
SealockRacing Offline
Alexandria, VA
used to do this with my little goped scooters, kept the piston from moving so i could take the flywheel nuts off!
