Roll cage #2248046
02/05/17 09:42 PM
02/05/17 09:42 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Is it better to use a front halo or have the two front bars go from the roll bar to the front pillar to the floor then tie them together at the top of the windshield?
Matt
Re: Roll cage [Re: MattW] #2248052
02/05/17 09:52 PM
02/05/17 09:52 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
Continuos bars from main hoop to the floor. A lot of kits use the roof hoop. All sfi require continuous bars from the main hoop for a reason.
Re: Roll cage [Re: Moparpoor] #2248057
02/05/17 10:02 PM
02/05/17 10:02 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Not true. SFI gives either option. Designer discretion. Kits with Halo bars are easier to fabricate. Full door down bars are more desirable, popular belief is that they are stronger in the event of a crash. Your choice, basically. IMHO, I think the full door bar is better. It took me 3 attempts to get them right, and I settled for what I built.
[image][/image]
Re: Roll cage [Re: MattW] #2248196
02/06/17 12:47 AM
02/06/17 12:47 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
25.5 and quicker requires a continuous bar. 12a or 12b is a continuous roof/windshield bar. 8.50 and slower may allow it.
Re: Roll cage [Re: Moparpoor] #2248320
02/06/17 08:34 AM
02/06/17 08:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe I've seen them both ways on 25.3
Doug
Re: Roll cage [Re: MattW] #2248336
02/06/17 10:23 AM
02/06/17 10:23 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
I actually got the books out lastnight to make sure I wasn't talking out of my rear lol. 25.3 is similar as 25.5 with more gussets and bars. 4130 or docol r8 only
Re: Roll cage [Re: MattW] #2248636
02/06/17 06:29 PM
02/06/17 06:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
My copy of the spec says the roof structure (#13 bar) can be formed by a one piece halo attached to the main hoop or with continuous side bars with a connecting (#13) bar. Also the 12A and 12B bars can be continuous with the dash (#11) bar attaching to them or the #11 bar can interrupt the #12 bars allowing them to be 2 pieces, as long as the #11 bar is the correct size.
Re: Roll cage [Re: CMcAllister] #2248759
02/06/17 10:16 PM
02/06/17 10:16 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
time to purchase a rule book!!
