Re: R5P7 Builds
[Re: Porter67]
#2245903
02/02/17 02:17 PM
02/02/17 02:17 PM
Posts: 11,712 Portage,michigan
B3422W5
Portage,michigan
Buddy of mine took a Busch motor ( restrictor plate motor), had a dinky 248/258 cam, 12 to 1 compression. Stuck it in a 68 Dart. Ran a 904 behind it and a 4150 carb. 2 inch W2 headers he tweaked to fit. At 3000 ish pounds it went low 9.40's at 143 mph best. Shifted it at around 7800.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: R5P7 Builds
[Re: Porter67]
#2245918
02/02/17 02:39 PM
02/02/17 02:39 PM
B3422W5
Portage,michigan
Was that a nascar cam or a reground core?
I hate to admit it but I dont even know what comp ratio mine will figure out to be.
Im more like 3600 pounds.
I do have a g force 101 I bought for the project.
Like many I got most my stuff from Scott E. and ive got a set of the nascar headers but have no clue what chassis they will fit, but they were cheap enough not to pass up, even to cut up for parts.
Im a little skiddish on getting the block work done, I need to find a shop that can handle it. Nascar cam it came with. Whole lot more on the table with several changes
Re: R5P7 Builds
[Re: B3422W5]
#2246568
02/03/17 03:25 PM
02/03/17 03:25 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You must not be in the right circles. Dodge R5 Mopar R5 Mopar/Dodge R5 swap and Tech These are all fb pages full of drag racers running these.
Installed a eei chip gannassi cup engine engine in my car 5 years ago. With a truck roller cam went 5.82@118 in 3,000 lb car with a best guess converter.
Been running these R5 ever sense. A few years back designed a bell housing to use with Reid case pg and t400 transmissions. Sell the whole kit. A couple folks made adapter plates for transmissions. We all have had trouble keeping up from time to time. I took the plunge and order 15 from manufacturer and sell a complete kit with flexplate. Also sell complete transmissions.
I have been 5teens with the r5 I run now. If not for some failing parts in rear suspension would have ran in the high 4's based on 60ft and mph.
Quite a few in Europe and Australia drag racing these also. Haven't seen anyone take the R5 out to go back to what they had.
Re: R5P7 Builds
[Re: Porter67]
#2246577
02/03/17 03:33 PM
02/03/17 03:33 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
What is the weight of one of these engines in complete trim?
Re: R5P7 Builds
[Re: Porter67]
#2246611
02/03/17 04:33 PM
02/03/17 04:33 PM
Leon441
Lynchburg, VA
Good question The block is skirted like big block with 6bolt main caps. But, the crank, rods, and pistons are light. Add 15-25 lbs for dry sump.
Re: R5P7 Builds
[Re: Porter67]
#2246877
02/03/17 11:11 PM
02/03/17 11:11 PM
Posts: 6,142 Melbourne , Australia
LA360
There aren't many people that have really got after it with these engines. Reality is they'll make as much , if not more than a SB2.2 engine. I know someone who started working on a 358 for A/EA in Comp Eliminator, but pulled the pin because he didn't think the interest would be there. This was close to 10 years ago.
Alan Jones
