R5P7 Builds #2245891
02/02/17 01:58 PM
02/02/17 01:58 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Has anyone had any really good productive luck merging these into a drag motor, I keep up on the couple on this site but still am not overly impressed.
I see they still sell ready to run ones on ebay for like 14k, Ive every single part and them some to build a brad new one and im at 8k in parts so I figure maybe 2k in machine work max.
But is it really worth it, to be that different?
I think street car, street rod, resto mod might be a better place for it.
Re: R5P7 Builds [Re: Porter67] #2245903
02/02/17 02:17 PM
02/02/17 02:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Buddy of mine took a Busch motor ( restrictor plate motor), had a dinky 248/258 cam, 12 to 1 compression. Stuck it in a 68 Dart. Ran a 904 behind it and a 4150 carb. 2 inch W2 headers he tweaked to fit.
At 3000 ish pounds it went low 9.40's at 143 mph best. Shifted it at around 7800.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 Builds [Re: Porter67] #2245912
02/02/17 02:31 PM
02/02/17 02:31 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Was that a nascar cam or a reground core?
I hate to admit it but I dont even know what comp ratio mine will figure out to be.
Im more like 3600 pounds.
I do have a g force 101 I bought for the project.
Like many I got most my stuff from Scott E. and ive got a set of the nascar headers but have no clue what chassis they will fit, but they were cheap enough not to pass up, even to cut up for parts.
Im a little skiddish on getting the block work done, I need to find a shop that can handle it.
Re: R5P7 Builds [Re: Porter67] #2245918
02/02/17 02:39 PM
02/02/17 02:39 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Nascar cam it came with. Whole lot more on the table with several changes
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 Builds [Re: B3422W5] #2246568
02/03/17 03:25 PM
02/03/17 03:25 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You must not be in the right circles.
Dodge R5
Mopar R5
Mopar/Dodge R5 swap and Tech
These are all fb pages full of drag racers running these.
Installed a eei chip gannassi cup engine engine in my car 5 years ago. With a truck roller cam went 5.82@118 in 3,000 lb car with a best guess converter.
Been running these R5 ever sense. A few years back designed a bell housing to use with Reid case pg and t400 transmissions. Sell the whole kit. A couple folks made adapter plates for transmissions. We all have had trouble keeping up from time to time. I took the plunge and order 15 from manufacturer and sell a complete kit with flexplate. Also sell complete transmissions.
I have been 5teens with the r5 I run now. If not for some failing parts in rear suspension would have ran in the high 4's based on 60ft and mph.
Quite a few in Europe and Australia drag racing these also. Haven't seen anyone take the R5 out to go back to what they had.
Re: R5P7 Builds [Re: Porter67] #2246577
02/03/17 03:33 PM
02/03/17 03:33 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What is the weight of one of these engines in complete trim?
Re: R5P7 Builds [Re: Porter67] #2246611
02/03/17 04:33 PM
02/03/17 04:33 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Good question
The block is skirted like big block with 6bolt main caps. But, the crank, rods, and pistons are light. Add 15-25 lbs for dry sump.
Re: R5P7 Builds [Re: Porter67] #2246789
02/03/17 08:30 PM
02/03/17 08:30 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Anyone looking for an R6 block? I'm going a different direction
Re: R5P7 Builds [Re: Porter67] #2246791
02/03/17 08:38 PM
02/03/17 08:38 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Your very very right, im just now at a point in my life, health and budget wise to move forward on the combo.
By no means am I meaning to discredit the ones who run them now but more rather Im in copy cat mode on the hard work of others.
Re: R5P7 Builds [Re: Porter67] #2246877
02/03/17 11:11 PM
02/03/17 11:11 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
There aren't many people that have really got after it with these engines. Reality is they'll make as much , if not more than a SB2.2 engine.
I know someone who started working on a 358 for A/EA in Comp Eliminator, but pulled the pin because he didn't think the interest would be there. This was close to 10 years ago.
Alan Jones
